I have keyboard and screen connected to my raspberry pi. I want to try running a video on a loop on startup (I do not want to install desktop environment to do so). In the past I have successfully used omxplayer. However omxplayer is deprecated. I went to their github trying to compile it, but even that failed, so I guess omxplayer is truly dead.
Thus I tried to switch to vlc... what a nightmare it is proving to be. So I got a brand new installation of raspberry pi.
This is what I run (dump from my history)
1 sudo apt-get update
2 sudo apt-get upgrade
3 sudo apt-get dist-upgrade
4 sudo apt-get install vlc
VLC tells me it is missing stuff, so I fix it
5 sudo apt-get install vlc --fix-missing
6 sudo mkdir /mnt/usb
7 sudo mount /dev/sda1 /mnt/usb
8 cvlc -L /mnt/usb/demo.mp4
And as soon as I run it I get this
VLC media player 3.0.17.4 Vetinari (revision 3.0.13-8-g41878ff4f2)
[0082c1b0] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
[00841f48] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[00841f48] main interface error: no suitable interface module
[007cbb98] main libvlc error: interface "dbus,none" initialization failed
[0083acd8] main interface error: no suitable interface module
[007cbb98] main libvlc error: interface "globalhotkeys,none" initialization failed
[0083acd8] dummy interface: using the dummy interface module...
error: XDG_RUNTIME_DIR not set in the environment.
[67a01460] gles2 generic error: parent window not available
[67a00ce0] mmal_xsplitter vout display error: Failed to open Xsplitter:opengles2 module
[67a01460] xcb generic error: window not available
[67a00ce0] mmal_xsplitter vout display error: Failed to open Xsplitter:xcb_x11 module
[67a00ce0] mmal_xsplitter vout display error: Failed to open Xsplitter:mmal_vout module
[67a00ce0] mmal_xsplitter vout display: Try drm
[67a01460] drm_vout generic: <<< OpenDrmVout: Fmt=DPS3
[67a01460] drm_vout generic error: Failed to get xlease
[67a13c28] chain filter error: Too high level of recursion (3)
[67a136c0] main filter error: Failed to create video converter
[72b0eb80] avcodec decoder: Using DRM Video Accel for hardware decoding
[hevc @ 0x72b1baf0] Failed setup for format drm_prime: hwaccel initialisation returned error.
[72b0eb80] avcodec decoder error: existing hardware acceleration cannot be reused
[67a01460] drm_vout generic: <<< OpenDrmVout: Fmt=I0AL
^C[67a01460] drm_vout generic error: AddFB2 failed: Invalid argument
[67a01460] drm_vout generic error: Failed to create frme buffer from pic
Then I thought it would be great idea to make vlc runnable as root so I do
9 sudo sed -i 's/geteuid/getppid/' /usr/bin/vlc
10 sudo cvlc -L /mnt/usb/demo.mp4
And it still gives same errors.
All I want to do is to boot up my raspberry pi and have it play a video on boot from the usb stick named demo.mp4
On omxplayer it was so easy. How do I do same with vlc? Do I absolutely have to install desktop environment?
I understand that giving up after only running 10 commands on the command line is lame. But I think I am out of options. I never had anything like this happen to me before, but then I am a young linux person.
sudo apt install vlc-plugin-base
. Noteapt-get
is deprecated so useapt
in the future. – MatsK Nov 24 '22 at 20:24vlc-plugin-base is already the newest version (3.0.17.4-0+deb11u1+rpi1+rpt4)
Thanks for telling me to use apt next time in the future, will do! – Quillion Nov 24 '22 at 21:59nodm
; read https://raspberrypi.stackexchange.com/a/83715/5538 and https://raspberrypi.stackexchange.com/a/57560/5538. – goldilocks Nov 25 '22 at 15:09[kiosk] autologin
). If I find time in the next few days, I might try and do this without a DM (and WM maybe) and post an answer here, but I think you have a good chance of finding something satisfactory in all the stuff above. If there's something in there you don't understand or that doesn't work the way you think it should, please ask another question specifically about that. – goldilocks Nov 25 '22 at 15:12nodm
was not created for nothing. – goldilocks Dec 03 '22 at 22:05
