I have a problem, I'm using a wifi adapter TL-WN725N. On the display when scanning, it says "No Wireless Interfaces Found".
I've used the solution from the website: https://gist.github.com/MBing/de297a8ae5e8a191c55a67a568d20d31
But, it's failed.
I want to use the solution from: http://downloads.fars-robotics.net/wifi-drivers/8188eu-drivers/
But, my kernel is not available.
My kernel:
Linux raspberrypi 5.10.63-v7+ #1496 SMP Wed Dec 1 15:58:11 GMT 2021 armv7l GNU/Linux
My OS Version:
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
When I do ifconfig, the wifi adapter can detect:
inet 192.168.100.1 netmask 255.255.255.0 broadcast 192.168.100.255
inet6 fe80::a19d:4bb7:cbb8:7252 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:45:d5:4a txqueuelen 1000 (Ethernet)
RX packets 6683 bytes 907655 (886.3 KiB)
TX packets 2714 bytes 487448 (476.0 KiB)
RX packets 952 bytes 83318 (81.3 KiB)
TX packets 952 bytes 83318 (81.3 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 9c:a2:f4:70:fb:f0 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
WiFi adapter can also scan using iwlist.
$ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 unassociated ESSID:"" Nickname:"<WIFI@REALTEK>"
Mode:Auto Frequency=2.412 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
wpa_supplicant.conf settinf
$cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
country=ID
network={
ssid="MY_WIFI"
psk="1234567890"
key_mgmt=WPA-PSK
However, when connecting to a WiFi Client (using wpa_supplicant.conf). Communication not connected. What's Happen?
