Following this answer I added a 2nd WiFi network to wpa_supplicant on my bullseye installation.
There must be something wrong with the configuration as when I reboot the router I am unable to connect to the Raspberry Pi on either network, effectively leaving me no way to connect to the device via SSH.
The configuration I used is:
update_config=1
network={ ssid="NETWORK1 NAME" psk=<secure version of psk added when configuring pi with imager software> id_str=""network_1 }
network={ ssid="NETWORK2 NAME" psk=PASSWORD2 id_str=""network_2 }
Can anyone see what I've done wrong here?
MatsK
  • 2,791
Vinyl Warmth
  • 109
You have two errors:
First error:
id_str=""network_1
should look like this
id_str="network_1"
And the same for network_2
And the second error:
If you read the first comment on https://raspberrypi.stackexchange.com/a/40144/149966
This does not appear to work if you specify id= but if you instead specify a priority= for each then it does work. –  Ian Mercer Oct 21, 2020 at 3:37
So add a priority=1 and priority=2 to network_1 and netwwork_2.
MatsK
  • 2,791
There is absolutely no point in attempting to use a 7 year old post for an obsolete OS!
There are OBVIOUS formatting errors in the strings you entered. Even if you corrected the id_str entry it is doubtful that these serve any useful purpose in modern networking.
You have NOT set a country=
See How to set up networking/WiFi
