I am trying to configure raspberry pi wifi module as AP and client at the same time on same wlan0 interface using Access point as WiFi router/repeater, optional with bridge this tutorial, the problem I am facing is that only one device gets connected to AP, if I try to connect second device the device goes to connected-disconnected-than continues saved state and do not gets connect. only the device which comes first gets connected none other, I have googled a lot but failed to find any solution. My files Configurations and logs are.
interface=ap@wlan0
#driver=nl80211
#ieee80211n=1
driver=nl80211
country_code=DE
ssid=embabcd
hw_mode=g
channel=11
wmm_enabled=1
#macaddr_acl=0
auth_algs=1
wpa=2
wpa_passphrase=12345678emb
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP CCMP
rsn_pairwise=CCMP
bridge=br0
ifconfig
ifconfig
ap@wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet6 fe80::e65f:1ff:fe90:f845  prefixlen 64  scopeid 0x20<link>
        ether e4:5f:01:90:f8:45  txqueuelen 1000  (Ethernet)
        RX packets 1689  bytes 393516 (393.5 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 1764  bytes 1085357 (1.0 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.4.1 netmask 255.255.255.0 broadcast 192.168.4.255 inet6 fe80::8069:27ff:fe56:1537 prefixlen 64 scopeid 0x20<link> ether 82:69:27:56:15:37 txqueuelen 1000 (Ethernet) RX packets 1852 bytes 416581 (416.5 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 1794 bytes 1047295 (1.0 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether e4:5f:01:90:f8:44 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 84 bytes 6160 (6.1 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 84 bytes 6160 (6.1 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.0.195 netmask 255.255.255.0 broadcast 192.168.0.255 inet6 fe80::e65f:1ff:fe90:f845 prefixlen 64 scopeid 0x20<link> ether e4:5f:01:90:f8:45 txqueuelen 1000 (Ethernet) RX packets 16375 bytes 12419366 (12.4 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 14483 bytes 2763990 (2.7 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
log of accesspoint@wlan0
journalctl --follow -u accesspoint@wlan0
Sep 16 15:06:13 rizvi hostapd[5672]: ap@wlan0: AP-ENABLED
Sep 16 15:07:26 rizvi hostapd[5672]: ap@wlan0: STA fe:6e:77:be:8e:f2 IEEE 802.11: associated
Sep 16 15:07:26 rizvi hostapd[5672]: ap@wlan0: AP-STA-POSSIBLE-PSK-MISMATCH fe:6e:77:be:8e:f2
Sep 16 15:07:28 rizvi hostapd[5672]: ap@wlan0: AP-STA-CONNECTED fe:6e:77:be:8e:f2
Sep 16 15:07:28 rizvi hostapd[5672]: ap@wlan0: STA fe:6e:77:be:8e:f2 RADIUS: starting accounting session CB5A7D34A8890A4B
Sep 16 15:07:28 rizvi hostapd[5672]: ap@wlan0: STA fe:6e:77:be:8e:f2 WPA: pairwise key handshake completed (RSN)
Sep 16 15:07:28 rizvi hostapd[5672]: ap@wlan0: EAPOL-4WAY-HS-COMPLETED fe:6e:77:be:8e:f2
Sep 16 15:32:11 rizvi hostapd[5672]: ap@wlan0: interface state ENABLED->DISABLED
Sep 16 15:32:11 rizvi hostapd[5672]: ap@wlan0: AP-STA-DISCONNECTED fe:6e:77:be:8e:f2
Sep 16 15:32:11 rizvi systemd[1]: Stopping accesspoint with hostapd (interface-specific version)...
Sep 16 15:32:11 rizvi hostapd[5672]: ap@wlan0: AP-DISABLED
Sep 16 15:32:11 rizvi hostapd[5672]: ap@wlan0: CTRL-EVENT-TERMINATING
Sep 16 15:32:11 rizvi hostapd[5672]: nl80211: deinit ifname=ap@wlan0 disabled_11b_rates=0
Sep 16 15:32:12 rizvi systemd[1]: accesspoint@wlan0.service: Deactivated successfully.
Sep 16 15:32:12 rizvi systemd[1]: Stopped accesspoint with hostapd (interface-specific version).
Sep 16 15:32:12 rizvi systemd[1]: Starting accesspoint with hostapd (interface-specific version)...
Sep 16 15:32:12 rizvi systemd[1]: Started accesspoint with hostapd (interface-specific version).
Sep 16 15:32:12 rizvi hostapd[7264]: nl80211: kernel reports: Match already configured
Sep 16 15:32:12 rizvi hostapd[7264]: ap@wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Sep 16 15:32:12 rizvi hostapd[7264]: ap@wlan0: interface state COUNTRY_UPDATE->ENABLED
Sep 16 15:32:12 rizvi hostapd[7264]: ap@wlan0: AP-ENABLED
Sep 16 15:32:44 rizvi hostapd[7264]: ap@wlan0: STA fe:6e:77:be:8e:f2 IEEE 802.11: associated
Sep 16 15:32:45 rizvi hostapd[7264]: ap@wlan0: STA fe:6e:77:be:8e:f2 WPA: received EAPOL-Key msg 2/4 in invalid state (10) - dropped
Sep 16 15:32:48 rizvi hostapd[7264]: ap@wlan0: STA fe:6e:77:be:8e:f2 IEEE 802.11: disassociated
Sep 16 15:32:50 rizvi hostapd[7264]: ap@wlan0: STA fe:6e:77:be:8e:f2 IEEE 802.11: associated
Sep 16 15:32:50 rizvi hostapd[7264]: ap@wlan0: AP-STA-CONNECTED fe:6e:77:be:8e:f2
Sep 16 15:32:50 rizvi hostapd[7264]: ap@wlan0: STA fe:6e:77:be:8e:f2 RADIUS: starting accounting session D054B04CBB8D0AEB
Sep 16 15:32:50 rizvi hostapd[7264]: ap@wlan0: STA fe:6e:77:be:8e:f2 WPA: pairwise key handshake completed (RSN)
Sep 16 15:32:50 rizvi hostapd[7264]: ap@wlan0: EAPOL-4WAY-HS-COMPLETED fe:6e:77:be:8e:f2
logs of hostapd.conf
journalctl --follow -u hostapd.service
Sep 16 15:07:26 rizvi hostapd[5779]: ap@wlan0: STA fe:6e:77:be:8e:f2 WPA: pairwise key handshake completed (RSN)
Sep 16 15:32:11 rizvi hostapd[5779]: ap@wlan0: STA fe:6e:77:be:8e:f2 IEEE 802.11: disassociated
Sep 16 15:32:17 rizvi systemd[1]: Stopping Access point and authentication server for Wi-Fi and Ethernet...
Sep 16 15:32:17 rizvi systemd[1]: hostapd.service: Deactivated successfully.
Sep 16 15:32:17 rizvi systemd[1]: Stopped Access point and authentication server for Wi-Fi and Ethernet.
Sep 16 15:32:17 rizvi systemd[1]: Starting Access point and authentication server for Wi-Fi and Ethernet...
Sep 16 15:32:17 rizvi hostapd[7380]: ap@wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Sep 16 15:32:17 rizvi hostapd[7380]: ap@wlan0: interface state COUNTRY_UPDATE->ENABLED
Sep 16 15:32:17 rizvi hostapd[7380]: ap@wlan0: AP-ENABLED
Sep 16 15:32:17 rizvi systemd[1]: Started Access point and authentication server for Wi-Fi and Ethernet.
Sep 16 15:32:44 rizvi hostapd[7381]: ap@wlan0: STA fe:6e:77:be:8e:f2 IEEE 802.11: associated
Sep 16 15:32:45 rizvi hostapd[7381]: ap@wlan0: STA fe:6e:77:be:8e:f2 RADIUS: starting accounting session 4903A63C880CEF5D
Sep 16 15:32:45 rizvi hostapd[7381]: ap@wlan0: STA fe:6e:77:be:8e:f2 WPA: pairwise key handshake completed (RSN)
Sep 16 15:32:48 rizvi hostapd[7381]: ap@wlan0: STA fe:6e:77:be:8e:f2 IEEE 802.11: disassociated
Sep 16 15:32:50 rizvi hostapd[7381]: ap@wlan0: STA fe:6e:77:be:8e:f2 IEEE 802.11: associated
Sep 16 15:32:52 rizvi hostapd[7381]: ap@wlan0: STA fe:6e:77:be:8e:f2 RADIUS: starting accounting session C68BAA6E40A7E98E
Sep 16 15:32:52 rizvi hostapd[7381]: ap@wlan0: STA fe:6e:77:be:8e:f2 WPA: pairwise key handshake completed (RSN)
Note : I am not allowed to use any other interface like eth0 or external wifi module. what should I do now.
  • One observation - the procedure you linked WAS NOT designed for Ubuntu and you HAVE NOT explained WHAT YOU DID. You tagged hostapd & systemd-networkd which is incomprehensible! – Milliways Sep 16 '22 at 11:44
  • what else information should I provide?. – Muhammad Sep 16 '22 at 11:51
0 Answers0
