One way (not necessarily the best way) to disable wlan0 on your RPi is with rfkill. Before going further, I should state the obvious for clarity: Once you've disabled wlan0, it cannot be used to communicate with the device. So - if wlan0 is your only interface, you will need to do some planing; i.e. how to connect to your RPi in the absence of wlan0.
That said, here's a cron job that should do what you want:
Since rfkill typically requires root privileges, we'll use root's crontab for this:
$ sudo crontab -e
root crontab opens in your chosen default editor...
The following crontab entries should toggle wlan0 ON at midnight (local time), and OFF again 3 minutes later:
0 0 * * * /usr/sbin/rfkill unblock wlan0
3 0 * * * /usr/sbin/rfkill block wlan0
Save your crontab & exit the editor. That should meet your minimum requirement; I'll leave it to you to embellish the crontab entries for output redirection - or development of a script to perform any related tasks.
You may also wish to consider how to handle things following a reboot. Let us know if you have further questions.
raspbian, so that narrows the range, but just to be clear, would you please confirm that you're using the defaultdhcpcdas your network manager? – Seamus Aug 29 '22 at 14:23
