I added init=/bin/sh to my cmdline.txt in an attempt to troubleshoot this problem, but upon booting I land at the normal credentials prompt.
I'm using a MicroSD adapter to edit the file with a Windows text editor, as that's the only other running OS I have available to me. The card apparently contains two partitions, as one is mounted (FAT32) but not the other (probably ext4). DISKPART doesn't show the second one either, nor does Disk Management.
Should I be editing a cmdline.txt file on the ext4 partition as well?
added init=/bin/sh to … cmdline.txtusing Raspberry Pi OS (and not NOOBS) this is IMPOSSIBLE! I don't doubt you have a problem, but without more information no one can help. – Milliways Aug 25 '22 at 01:25init=/bin/shtocmdline.txtin the root of the FAT32 partition. I double- and triple-checked it, as well as booted several times after the edit. No sauce. I'm at a loss as to what information I can give that I already haven't, but now that you mention it I do seem to remember having installed NOOBS on it all those many moons ago. Would that explain this whole mashup, do you think? – InteXX Aug 25 '22 at 01:31"... edit the file with a Windows text editor, ..."You know that's a problem, right? Your text must conform to Unix/Linux conventions for the newline - Windows usesCR-LF, Linux usesLF(now NL/newline) only (ref). – Seamus Aug 29 '22 at 18:08You know that's a problem, right?Yes, I'm aware (I mentioned it briefly here). However, I'm convinced now that I was editing the wrong file to begin with—thecmdline.txtfile in the root of the FAT32 partition, not the one in/boot. I was about to try @NomadMaker's suggestion, so I could get at/boot/cmdline.txt, when the recollection of my having installed NOOBS at the time hit me. That's when I threw in the towel and decided to reformat. I'm much better off for it, as I'm now running 64-bit. But thanks for reaffirming it! – InteXX Aug 30 '22 at 19:28
