I want to connect locally Raspberry Pi 4 model B via ethernet with GUI.
I go with this instructions: https://howchoo.com/pi/find-your-raspberry-pis-ip-address.
But command sudo nmap -sn 192.168.1.0/24 don't return raspberry Pi board IP. Then I find this instructions: Cannot connect to Pi Zero through SSH headless mode. And I can't modify config.txt file. I tried this one : How to edit config.txt. And command sudo mount -o remount,rw /boot return mount: /boot: mount point not mounted or bad option..
When try to connect to Raspberry Pi via VNC Viewer, I connect board via ethernet, I have got The connection was refused by the computer. This is vncviewer.log:
<14> 2022-07-25T12:55:25.580Z dmitriy vncviewer[22977]: Child: 26651: Localize: Locales en_US
<14> 2022-07-25T12:55:25.580Z dmitriy vncviewer[22977]: Child: 26651: CModuleHosted: Getting CloudConfig.pkg from built-in resource
<14> 2022-07-25T12:55:25.580Z dmitriy vncviewer[22977]: Child: 26651: CModuleHosted: Using business identifier 7ebb19da-7740-4238-8f0e-d5d8bc77f350
<14> 2022-07-25T12:55:25.580Z dmitriy vncviewer[22977]: Child: 26651: CModuleCtrlComms: Listening on /tmp/.vnc-1000/vncviewer.CtrlComms.26651
<14> 2022-07-25T12:55:25.580Z dmitriy vncviewer[22977]: Child: 26651: GoogleAnalytics: X.509 Error: Certificate expired
<13> 2022-07-25T12:55:25.580Z dmitriy vncviewer[22977]: Child: 26651: CSession: Connecting to 192.168.1.249 (Chooser for Direct UDP/Direct TCP via proxy settings)
<11> 2022-07-25T12:55:25.616Z dmitriy vncviewer[22977]: Child: 26651: CSession: connection error: connect: Connection refused (111)
<13> 2022-07-25T12:55:25.616Z dmitriy vncviewer[22977]: Child: 26651: CConnection: close: [System-111] The connection was refused by the computer
The output of nmap -sn 192.168.1.0/24:
Starting Nmap 7.80 ( https://nmap.org ) at 2022-07-25 16:13 MSK
Nmap scan report for 192.168.1.0
Host is up (0.044s latency).
Nmap scan report for 192.168.1.1
Host is up (0.0059s latency).
Nmap scan report for 192.168.1.4
Host is up (0.0064s latency).
Nmap scan report for 192.168.1.5
Host is up (0.085s latency).
Nmap scan report for 192.168.1.52
Host is up (0.0020s latency).
Nmap scan report for 192.168.1.98
Host is up (0.0014s latency).
Nmap scan report for 192.168.1.145
Host is up (0.0035s latency).
Nmap scan report for 192.168.1.147
Host is up (0.0030s latency).
Nmap scan report for 192.168.1.152
Host is up (0.099s latency).
Nmap scan report for 192.168.1.161
Nmap scan report for 192.168.1.182
Host is up (0.0021s latency).
Nmap scan report for 192.168.1.189
Host is up (0.22s latency).
Nmap scan report for 192.168.1.198
Host is up (0.062s latency).
Nmap scan report for 192.168.1.222
Host is up (0.077s latency).
Nmap scan report for 192.168.1.224
Host is up (0.078s latency).
Nmap scan report for 192.168.1.238
Host is up (0.52s latency).
Nmap scan report for 192.168.1.240
Host is up (0.074s latency).
Nmap scan report for 192.168.1.242
Host is up (0.14s latency).
Nmap scan report for 192.168.1.243
Host is up (0.19s latency).
Nmap scan report for 192.168.1.246
Host is up (0.11s latency).
Nmap done: 256 IP addresses (20 hosts up) scanned in 13.57 seconds
