I am trying to connect keyboard on my raspberry pi alongwith hdmi. But when i connect keyboard to the rpi, hdmi stops working and vice versa. But they both are working alone but not together. Any ideas how i can make them both work together.
This is my config.txt file and these are my current configuration for running hdmi on rpi.
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
**disable_overscan=0**
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=16
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
any thing i am doing wrong?? Any help would be appreciated.
Tejvir Singh
unprotected
- Which has it dangers. NO short circuit protection, no overload protection and generally just, mostly unrestricted. How much AMP's you giving it??? – Piotr Kula Feb 20 '14 at 14:40
