I have a raspi image that I use to duplicate other pi's, sometimes I want to have more than one of them connected to my network so I can test things all at once. However, they get confused on the network as their network settings are the exact same. I tried to solve this by setting a static IP address for one pi, but each time I try to do that I can't get a successful ping.
I tried following the solution here How do I set up networking/WiFi/static IP address on Raspbian/Raspberry Pi OS?
but that didn't work. I'm pretty green on networking issues, so I'm not sure what else I can change to troubleshoot. Any help is appreciated.
ifconfig results:
inet 192.168.50.10 netmask 255.255.255.0 broadcast 192.168.50.255
inet6 fe80::8237:8fa8:2a06:c5c7 prefixlen 64 scopeid 0x20<link>
ether c8:3e:a7:01:3e:ad txqueuelen 1000 (Ethernet)
RX packets 1313 bytes 230370 (224.9 KiB)
TX packets 1050 bytes 137704 (134.4 KiB)
RX packets 358 bytes 33382 (32.5 KiB)
TX packets 358 bytes 33382 (32.5 KiB)
cat /etc/resolv.conf results:
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 192.168.0.1
nameserver 8.8.8.8
nameserver fd51:42f8:caae:d92e::1
route -ne results:
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
192.168.0.1 0.0.0.0 255.255.255.255 UH 0 0 0 eth0
192.168.50.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
sudo service dhcpcd status results:
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2022-06-21 09:23:39 EDT; 7min ago
Process: 983 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=0/SUCCESS)
Main PID: 1091 (dhcpcd)
Tasks: 1 (limit: 4915)
CGroup: /system.slice/dhcpcd.service
└─1091 /sbin/dhcpcd -q -b
Jun 21 09:23:45 121321001 dhcpcd[1091]: control command: /sbin/dhcpcd --exit piright
Jun 21 09:23:45 121321001 dhcpcd[1091]: piright: removing interface
Jun 21 09:23:45 121321001 dhcpcd[1091]: control command: /sbin/dhcpcd --exit pileft
Jun 21 09:23:45 121321001 dhcpcd[1091]: pileft: removing interface
Jun 21 09:23:47 121321001 dhcpcd[1091]: eth0: using static address 192.168.50.10/24
Jun 21 09:23:47 121321001 dhcpcd[1091]: eth0: router 192.168.0.1 requires a host route
Jun 21 09:23:47 121321001 dhcpcd[1091]: eth0: adding route to 192.168.50.0/24
Jun 21 09:23:47 121321001 dhcpcd[1091]: eth0: adding host route to 192.168.0.1
Jun 21 09:23:47 121321001 dhcpcd[1091]: eth0: adding default route via 192.168.0.1
Jun 21 09:24:09 121321001 dhcpcd[1091]: eth0: no IPv6 Routers available
My router has this info: IPv4 Address: 192.168.50.212
andI think the 212 is my laptops IP address
don't match. What is the IP address of the router itself? – virmaior Jun 21 '22 at 14:38static ip_address=192.168.50.10/24 static ip6_address=fd51:42f8:caae:d92e::ff/64 static routers=192.168.0.1 static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
Router IP is 192.168.50.1
– TKnapp Jun 21 '22 at 14:40
