I am trying to establish a wired connection between my RPi 3 B+ and my MacBook Air. After I connected the two devices with a wire, my MacBook got IP=169.254.214.218, and my RPi got IP=10.0.0.21. When I pinged my RPi from my MacBook, ping recognized the name "realtimepi.local" (IP=10.0.0.21). However, the requests always went timeout. When I pinged my MacBook from my RPi, ping only occasionally recognized "<my MacBook's name>.local", so I pinged 169.254.214.218 directly. The requests always encountered the error "Destination Host Unreachable". I checked several related posts and ran some commands to diagnose this problem but in vain. The following is what I have known so far. Could someone share any thoughts/feedback? Thanks.
I found that my MacBook's IP indicated that the DHCP server is not reachable. I am unsure if this is the cause and why. On my MacBook, I have set "Configure IPv4: Using DHCP", "Location: Automatic", "Configure IPv6: Automatically", and "DNS Servers: 10.0.0.1, 10.10.10.10, ..., 8.8.8.8, ...".
My RPi has been configured to automatically search for and connect to my phone's Wi-Fi. My MacBook can then communicate with my RPi wirelessly. In this way, I ssh-logged into my RPi, ran ifconfig, route -n, ip route ls, and checked /etc/dhcpcd.conf.
pi@realtimepi:~ $ ifconfig
inet 10.0.0.21 netmask 255.255.255.0 broadcast 10.0.0.255
inet6 fe80::cebe:1e7a:d284:3733 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:01:cc:42 txqueuelen 1000 (Ethernet)
RX packets 695 bytes 220566 (215.3 KiB)
TX packets 266 bytes 13230 (12.9 KiB)
RX packets 167 bytes 16130 (15.7 KiB)
TX packets 167 bytes 16130 (15.7 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.43.228 netmask 255.255.255.0 broadcast 192.168.43.255
inet6 fe80::a639:4e7c:b4ef:f5e5 prefixlen 64 scopeid 0x20<link>
inet6 2607:fb90:6e2c:1057:abd:aa36:70c7:7123 prefixlen 64 scopeid 0x0<global>
ether b8:27:eb:54:99:17 txqueuelen 1000 (Ethernet)
RX packets 811 bytes 90049 (87.9 KiB)
TX packets 476 bytes 72780 (71.0 KiB)
pi@realtimepi:~ $ route -n
Kernel IP routing table
0.0.0.0 10.0.0.1 0.0.0.0 UG 202 0 0 eth0
0.0.0.0 192.168.43.1 0.0.0.0 UG 303 0 0 wlan0
10.0.0.0 0.0.0.0 255.255.255.0 U 202 0 0 eth0
192.168.43.0 0.0.0.0 255.255.255.0 U 303 0 0 wlan0
pi@realtimepi:~ $ ip route ls
default via 10.0.0.1 dev eth0 src 10.0.0.21 metric 202
default via 192.168.43.1 dev wlan0 src 192.168.43.228 metric 303
10.0.0.0/24 dev eth0 proto kernel scope link src 10.0.0.21 metric 202
192.168.43.0/24 dev wlan0 proto kernel scope link src 192.168.43.228 metric 303
part of /etc/dhcpcd.conf, the unlikely relevant lines omitted
interface eth0
static ip_address=10.0.0.21/24
static routers=10.0.0.1
static domain_name_servers=10.0.0.1 8.8.8.8
interface eth0
nogateway
I also ran ifconfig on my MacBook.
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
inet 127.0.0.1 netmask 0xff000000
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=400<CHANNEL_IO>
ether 48:bf:6b:d3:2f:de
inet6 fe80::1810:2058:e5a0:4491%en0 prefixlen 64 secured scopeid 0x4
inet 192.168.43.173 netmask 0xffffff00 broadcast 192.168.43.255
inet6 2607:fb90:6e2c:1057:4e6:3b53:93b:f117 prefixlen 64 autoconf secured
inet6 2607:fb90:6e2c:1057:15b5:d130:cc2b:1e16 prefixlen 64 autoconf temporary
media: autoselect
status: active
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
options=460<TSO4,TSO6,CHANNEL_IO>
ether 82:18:34:12:02:40
media: autoselect <full-duplex>
status: inactive
bridge0: flags=8822<BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
options=63<RXCSUM,TXCSUM,TSO4,TSO6>
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x0
member: en1 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 5 priority 0 path cost 0
media: <unknown type>
status: inactive
p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304
ether 0a:bf:6b:d3:2f:de
media: autoselect
status: inactive
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1484
ether 96:9e:70:32:fd:dd
inet6 fe80::949e:70ff:fe32:fddd%awdl0 prefixlen 64 scopeid 0x8
media: autoselect
status: active
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
inet6 fe80::949e:70ff:fe32:fddd%llw0 prefixlen 64 scopeid 0x9
media: autoselect
status: active
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::1d3f:f1bc:8034:44e3%utun0 prefixlen 64 scopeid 0xa
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::bedd:ab54:da62:8d19%utun1 prefixlen 64 scopeid 0xb
en3: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=50b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO>
ether a8:60:b6:00:77:85
inet6 fe80::834:760f:3480:a927%en3 prefixlen 64 secured scopeid 0xc
inet 169.254.214.218 netmask 0xffff0000 broadcast 169.254.255.255
media: autoselect (1000baseT <full-duplex,flow-control,energy-efficient-ethernet>)
status: active
I hope these results help. I will supply more if needed.
