I am building a sorting machine for a project where I want to sort the balls based on their color. For the actual sorting mechanism I am using a stepping motor (NEMA 17 with Driver DRV8825). I followed the steps from here to set up the connections between the PI and the motor. For my use case, I want to rotate the motor in either direction depending on the ball color. So, I am rotating my motor say 20 steps in one direction and then halt it for a few microseconds and then return it to the middle position (kind of pendulum but controlled). However, the actual behaviour is very different. Sometimes the motor works fine and then all of sudden it just rotates in one direction and the motion is also jerky (even if I set the motor to rotate in the other direction by changing the DIRECTION pin value). I have also added the code here which I am using
import RPi.GPIO as GPIO
from RpiMotorLib import RpiMotorLib
import time
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
direction= 10 # Direction (DIR) GPIO Pin
step = 25 # Step GPIO Pin
EN_pin = 8 # enable pin (LOW to enable)
Declare a instance of class pass GPIO pins numbers and the motor type
mymotortest = RpiMotorLib.A4988Nema(direction, step, (21,21,21), "DRV8825")
GPIO.setup(EN_pin,GPIO.OUT) # set enable pin as output
GPIO.setup(direction, GPIO.OUT)
GPIO.setup(step, GPIO.OUT)
step_type = "Full"
steps = 20
step_delay = 0.0008
initial_delay = 0
def halt_step():
GPIO.output(step, GPIO.HIGH)
time.sleep(0.5)
GPIO.output(step, GPIO.LOW)
def middle(ccw=True):
#GPIO.output(EN_pin,GPIO.LOW) # pull enable to low to enable motor
mymotortest.motor_go(ccw, # True=Clockwise, False=Counter-Clockwise
step_type, # Step type (Full,Half,1/4,1/8,1/16,1/32)
steps, # number of steps
step_delay, # step delay [sec]
False, # True = print verbose output
initial_delay)
GPIO.output(EN_pin,GPIO.HIGH)
def left():
mymotortest.motor_go(False, # True=Clockwise, False=Counter-Clockwise
initial_delay)
halt_step()
middle(True)
def right():
mymotortest.motor_go(True, # True=Clockwise, False=Counter-Clockwise
initial_delay)
halt_step()
middle(False)
if name == "main":
import random
for i in range(10):
flag = random.random()
#print(flag)
if flag < 0.5:
print(f"{flag}:Left")
left()
else:
print(f"{flag}:Right")
right()
time.sleep(1)
GPIO.cleanup()
Any kind of help is appreciated, as I am kind of stuck here. I am new to the stepper motors, so I have no idea if something is wrong there.
