I try to use hardware PWM on RPI 3b+ (Linux 11 bullseye) by using bcm2835.h (ver. 1.71) with small C code given below
#include <bcm2835.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
int main(int argc, char **argv)
    if (!bcm2835_init()) return 1;
bcm2835_gpio_fsel(18, BCM2835_GPIO_FSEL_ALT5);
bcm2835_pwm_set_clock(2);
bcm2835_pwm_set_mode(0, 1, 1);
bcm2835_pwm_set_range(0, 2);
bcm2835_pwm_set_data(0, 1);
bcm2835_close();
return 0;
It was compiled, built and run with no errors, but oscilloscope connected to corresponding pin shows that output signal has duty cycle approx ~ 99%, not 50%, as expected. Changing corresponding argument in bcm2835_pwm_set_data() has no effect, duty cycle does not change. Changing arguments in bcm2835_pwm_set_clock() and bcm2835_pwm_set_range(0, 2) result in frequency changing, but duty cycle does not varying! Why it could be?
WiringPiis deprecated, or refer to its demise. As I've explained, wiringPi is still available from their GitHub site, and available forbullseyeas a.debfile - easily installed and quite functional AFAICS. Is your experience different? – Seamus Apr 14 '22 at 22:35
