-1
For an application on my Raspberry Pi Zero W I need WIFI access. Developing at home worked great, but when I try to connect to any other WIFI network than my home WIFI I just cannot establish any internet connection.
Following several tutorials I did the initial configuration on the headless system via the wpa_supplicant.conf looking like this:
update_config=1
country=DE
network={ ssid="MYSSID" psk="MYPW" key_mgmt=WPA-PSK }
I also set a static IP in my dhcpcd.conv via
interface wlan0
inform 192.168.0.100
When I now edit ssid and psk in the file to use some other WIFI the connection cannot be established. I test this via ping www.google.com which returns "temporary failure in name resolution". Switching back to the original WIFI credentials afterwards and the ping works fine again. I also tried adding the google-nameserver 8.8.8.8 and 8.8.8.4 to the /etc/resolv.conf without any impact.
FYI: /etc/os-release tells me "Raspbian GNU/Linux 10 (buster)" I tried "normal" routers as well as laptop or mobile hotspots. None work. I do not use any fancy network-software like pihole or anything alike just the plain default configuration. Does not matter weather i just reboot after wpa_supplicant change or use wpa_cli -i wlan0 reconfigure.
Any hints on what else to try?
Thanks and best regards.
Felix_N
    Are you sure the static IP address is valid in the other networks? Have you tried using DHCP – Dirk Apr 01 '22 at 20:32
  • Why are you trying to set a "static IP"? What you have will NOT. Get rid of the inform and let the router do the work. While many routers use 192.168 very many (including mine) do not. – Milliways Apr 01 '22 at 21:22
  • I use the static IP to connect via ssh for debugging. – Felix_N Apr 02 '22 at 07:10
To answer the question of connection to multiple networks just add multiple network={} stanzas. Mine has 12. You can also assign priority to each network.
See Networking Files in How to set up networking/WiFi
