Please note this is not a duplicate of How to disable the dynamic IP address after assigning a static IP in Bullseye? this previous problem occurred when a system that was updated from Buster to Bullseye.
I have a new install of Bullseye on Raspberry Pi 3B. It is connected to a TP-Link Archer AX50 router running stock firmware. I had a static IP address setup with the following addition to the file /etc/dhcpcd.conf:
interface eth0
static ip_address=192.168.0.65/24
static routers=192.168.0.1
static domain_name_servers=192.168.0.1
Following the advice of @Seamus, See this answer:
IP address missing from router DCHP table
I removed the last three lines and made the following change.
interface eth0
inform 192.168.0.65
Now I have two IP addresses. The command hostname I and sudo dhclient -vshow:
$ hostname -I
192.168.0.65 192.168.0.146
$ sudo dhclient -v
[sudo] password for sushenjit:
Internet Systems Consortium DHCP Client 4.4.1
Copyright 2004-2018 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
RTNETLINK answers: Operation not possible due to RF-kill
Listening on LPF/wlan0/b8:27:eb:f9:be:df
Sending on LPF/wlan0/b8:27:eb:f9:be:df
Listening on LPF/eth0/b8:27:eb:ac:eb:8a
Sending on LPF/eth0/b8:27:eb:ac:eb:8a
Sending on Socket/fallbackreceive_packet failed on wlan0: Network is down
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
send_packet: Network is down
dhclient.c:2446: Failed to send 300 byte long packet over wlan0 interface.
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 7
DHCPOFFER of 192.168.0.146 from 192.168.0.1
DHCPREQUEST for 192.168.0.146 on eth0 to 255.255.255.255 port 67
DHCPACK of 192.168.0.146 from 192.168.0.1
bound to 192.168.0.146 -- renewal in 2852 seconds.
$ ip address show
inet6 ::1/128 scope host
link/ether b8:27:eb:ac:eb:8a brd ff:ff:ff:ff:ff:ff
inet 192.168.0.65/24 brd 192.168.0.255 scope global noprefixroute eth0
inet 192.168.0.146/24 brd 192.168.0.255 scope global secondary dynamic eth0
valid_lft 4479sec preferred_lft 4479sec
inet6 fe80::9f8c:f503:5a46:ab25/64 scope link
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether b8:27:eb:f9:be:df brd ff:ff:ff:ff:ff:ff
Note, the TP-Link Archer AX50 assigns dynamic IP addresses in the range of: 192.168.0.100-192.168.0.249.
I don’t want the dynamic IP address 192.168.0.146 assigned to my Pi. However, I only want the 192.168.0.65 IP address. How do I do this without reverting the change?
Edit: Output of systemctl status dhcpcd:
$ systemctl status dhcpcd
● dhcpcd.service - DHCP Client Daemon
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-03-31 17:22:10 EDT; 2h 30min ago
Docs: man:dhcpcd(8)
Process: 416 ExecStart=/usr/sbin/dhcpcd -b -q (code=exited, status=0/SUCCESS)
Main PID: 490 (dhcpcd)
Tasks: 2 (limit: 1597)
CPU: 53min 45.506s
CGroup: /system.slice/dhcpcd.service
├─490 /usr/sbin/dhcpcd -b -q
└─556 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
Mar 31 19:52:59 raspberrypi dhcpcd[490]: eth0: received approval for 192.168.0.65
Thanks
dhclienton an interface that already has a lease, the router offers it the existing address and it accepts it, so my premise was perhaps wrong (answer deleted), all apologies. However, note thatdhclientdoes still keep running which may foul things up. You should check post boot that it is not being started for whatever strange reason:ps -C dhclient. – goldilocks Apr 01 '22 at 20:36
