I have a Raspberry Pi 3 Model B Plus Rev 1.3 in my Ethernet network that runs headless with octoprint and an arduino pro mini connected to it via i2c. Wifi is disabled. The Rpi is powered from an official rpi power supply and the arduino has a dedicated 5v power supply. Rpi and arduino share a ground pin.
During the last week or so I tried to make a small flask page to control the rpi and the pro mini. I usually open two ssh sessions with putty, I run the development server in one session and the other is used for editing, etc. I load the flask page remotely from my pc with firefox successfully. However after some time -randomly- after I load some corrections/reloads to the page, I am kicked out of the ssh session. The other session usually is alive but again it may die as well. The rpi is alive, it is not crashing.
Looking at the following logs in /var/log/kern.log , messages , syslog, and dmesg I don't see anything.
I changed cables and Ethernet ports in the switch but the problem persists.
If this is a power thing how do I go around to verify it? If it is an Ethernet thing where do I look, what log do I look? If it is a time out of some sort what do I try and where (putty, rpi?) Is there any other suggestion? Thank you all!
  1. Edit:
I have noticed also that although the session running the flask development server drops, the port and daemon/service still runs. I get an OSError: [Errno 98] Address already in use, when logging in again and trying to re-start flask. All sessions are down but the flask web server is running in the background. Also, the octoprint and 3d printing works without problems. This shows I think that it is not an Ethernet issue since octoprint continuously is in touch with a client pc.
  1. Edit:
I have a putty log to post here if it shows anything (because of the length I have put the last incoming and last outgoing unsuccessfully):
Incoming packet #0x1de, type 94 / 0x5e (SSH2_MSG_CHANNEL_DATA)
  00000000  00 00 01 00 00 00 00 78 31 39 32 2e 31 36 38 2e  .......x192.168.
  00000010  31 2e 31 30 31 20 2d 20 2d 20 5b 33 30 2f 4d 61  1.101 - - [30/Ma
  00000020  72 2f 32 30 32 32 20 30 39 3a 33 33 3a 30 39 5d  r/2022 09:33:09]
  00000030  20 22 47 45 54 20 2f 62 61 73 69 63 5f 63 6f 6c   "GET /basic_col
  00000040  6f 75 72 3f 5f 5f 64 65 62 75 67 67 65 72 5f 5f  our?__debugger__
  00000050  3d 79 65 73 26 63 6d 64 3d 72 65 73 6f 75 72 63  =yes&cmd=resourc
  00000060  65 26 66 3d 75 62 75 6e 74 75 2e 74 74 66 20 48  e&f=ubuntu.ttf H
  00000070  54 54 50 2f 31 2e 31 22 20 32 30 30 20 2d 0d 0a  TTP/1.1" 200 -..
Outgoing packet #0x43, type 2 / 0x02 (SSH2_MSG_IGNORE)
  00000000  00 00 00 00                                      ....
Outgoing raw data at 2022-03-30 09:33:14
  00000000  97 ff ec 7b 24 fe 7b b7 92 f7 f4 e1 54 fb 75 68  ...{$.{.....T.uh
  00000010  39 43 e4 b2 72 1e fe a2 84 3a ec 46 1a b3 ba bc  9C..r....:.F....
  00000020  35 fa 42 82 05 bd 56 91 24 ac e7 69 3c ab 64 a9  5.B...V.$..i<.d.
Outgoing packet #0x44, type 2 / 0x02 (SSH2_MSG_IGNORE)
Outgoing raw data at 2022-03-30 09:33:24
  00000000  38 f0 ed 3a c1 5c fa a4 7f 09 2a b8 51 a5 a2 02  8..:.\....*.Q...
  00000010  6f a9 42 dc c1 12 a4 45 ec 79 60 5c 37 c0 ce d5  o.B....E.y`\7...
  00000020  6a 1d 66 af 8d 13 bf 91 80 b2 61 6d b3 71 d6 e6  j.f.......am.q..
Outgoing packet #0x45, type 2 / 0x02 (SSH2_MSG_IGNORE)
Outgoing raw data at 2022-03-30 09:33:34
  00000000  a8 2b 75 cb f0 7e 30 83 82 34 26 d9 92 5f 79 5c  .+u..~0..4&.._y\
  00000010  d3 03 9c 29 8f 5c 61 4f cd 67 11 02 e0 37 d7 49  ...).\aO.g...7.I
  00000020  25 6a cc e0 ca 4d 41 77 73 a9 ef ff a8 7c e2 48  %j...MAws....|.H
Outgoing packet #0x46, type 2 / 0x02 (SSH2_MSG_IGNORE)
Outgoing raw data at 2022-03-30 09:33:44
  00000000  d6 30 83 ea fa 85 4f 16 bc 01 5b 53 5b 99 41 ea  .0....O...[S[.A.
  00000010  e2 b7 57 cc 2a 0c df 17 4b 6f 16 af a1 b3 f8 b4  ..W.*...Ko......
  00000020  79 df 7d 51 47 ce bb cd b7 7b d7 88 34 8d c0 9e  y.}QG....{..4...
Event Log: Network error: Software caused connection abort
Rohit Gupta
  • 281
thermike
  • 39
  • Curious - this is the 2nd Q today re failed SSH connections. The other one was here. – Seamus Mar 24 '22 at 08:35
  • Now my Edit1 comment "..This shows I think that it is not an Ethernet issue since octoprint continuously is in touch with a client pc..." seems not to be entirely true. Searching around I found this link [link] https://devanswers.co/ubuntu-ssh-keeps-disconnecting-idle/ and followed the check list there. – thermike Apr 06 '22 at 16:26
  • In the paragraph "Still Getting Disconnected? Check for an unreliable Internet connection" , I opened a command window in my win pc and started pinging continuously the rpi. I realized that in random moments I was getting a "Request timed out". I can't figure out what the cause is. I took some measures like changed the switch that the rpi was connected to, ports, patch cords. I had already tried some before but I tried again. Now I am monitoring the connection. – thermike Apr 06 '22 at 16:28
  • I noticed something in your Q that I'd not seen before: Address already in use.... If I can be nosy, have you set your RPi with a static ip address? If so, may I ask how you did that (e.g. in dhcpcd.conf, etc)? – Seamus Apr 06 '22 at 18:06
  • @Seamus To set a static address in Raspbian edit the file sudo nano /etc/dhcpcd.conf Then all you need to do is append this to the bottom of the file, substituting the correct IP address you want. interface eth0 static ip_address=xxx.xxx.xxx.xxx/24 static routers=xxx.xxx.xxx.yyy static domain_name_servers=xxx.xxx.xxx.zzz Restart your Pi The message though "Address already in use..." is brought because I try to re run the flask server which is not down and waits for calls ina specific port – thermike Apr 07 '22 at 07:42
  • Maybe you should consider following the advice of the author of dhcpcd? If you refer to man dhcpcd.conf, you will find this statement in the static [value] section: "For IPv4, you should use the inform ipaddress option instead of setting a static address.". Do you have a corresponding entry in your router & DHCP server configuration? – Seamus Apr 07 '22 at 14:53
  • @Seamus can you explain this a bit more please? I need to know a fixed ip for this device. – thermike Apr 08 '22 at 16:30
  • I've tried to explain this recently, without much luck. I am not the sharpest pencil in the box, but once I read the DHCP Standard - RFC 2131, it became obvious to me why Roy Marples advises against using the static ip option. dhcpcd is more than a DHCP client - it's RPi's *network manager*. Anyone who uses it to set a static ip option is poorly informed. But - I've learned recently, there are many poorly informed. – Seamus Apr 08 '22 at 17:59
  • An idea: If you'll post a new (clear & "good") question, I'll take another run at it. I've always loathed proselytizers and evangelists, and now I'm one of them it seems :) – Seamus Apr 08 '22 at 18:01
Have you tried pinging the Pi from another PC?
Does the ethernet interface stay up? E.G. does ifconfig show an IP address for your ethernet interface? (Usually called eth0)
You could try removing pieces of your Flask setup, to check when this random disconnect stops happening.
Maybe the Flask logs show something interesting?
  • @mats-de-waart pinging is 100% successful. ifconfig shows the ip for eth0. it isn't the session with the flask server running that drops the connection. – thermike Mar 24 '22 at 13:34
  • rpi ip is static , hostname -I reports the ip correctly and ip r | grep default reports the router correctly. – thermike Mar 24 '22 at 13:43
  • Hmm... Weird. Have you tried SSH'ing from another PC? Might be your host PC that is the problem.
    Also, if you have the time/hardware available, try rebuilding your setup on a fresh Pi with a fresh install of your OS on the SD card
    – Mats de Waard Mar 24 '22 at 16:16
  • I ran a utility for hardware checking in my pc. No problems found. Rebuilding everything isn't easy. I have to look for possible causes first. – thermike Mar 26 '22 at 13:36
  • Understandable, and trying to SSH from another host completely? Or Maybe with anoter piece of software? – Mats de Waard Mar 27 '22 at 14:28
  • Yes I tried to run ssh from another terminal and I had similar behavior. I tried to change the seconds between keepalives in putty, I changed from 0 to 10 seconds) but it didn't change anything. – thermike Mar 28 '22 at 16:43
  • Does from another terminal also mean from a completely different PC (host)? Or just another piece of software? Because it might also be the problem from your Host's OS dropping it's network adapter or something. Preferably try it with another machine, which runs another OS than your current host is using. – Mats de Waard Mar 29 '22 at 07:34
  • It is a completely different computer, actually it is a mac. I make an ssh connection and run the flask server as I did from my win pc. – thermike Mar 30 '22 at 06:42
  • Hmm... Really weird. My next bet would probably be to directly connect the Pi to your host machine with an ethernet cable (so not through your modem or router) and give both computers a static IP with the same default gateway. Then see if the problem still persists that way. (Hopefully you can fully test without Flask or Octoprint being connected to the web) – Mats de Waard Mar 30 '22 at 08:05
It's possible this is a putty issue, as opposed to raspberry pi specifically. I frequently have to have multiple putty tabs open and connected at work, and disconnections/timeouts are frequent, especially if I haven't actively input commands recently (also at times, when running a .jar executable, timeouts will occur even though the java process is still ongoing.) Sometimes connections will timeout/disconnect twice in the span it takes another to disconnect
Based on your information, it seems the Pi itself is still online throughout these disconnects and timeouts. I would try playing around with putty settings, specifically keepalive settings. You can find these options under the 'Connection' tab before you connect to your pi, specifically enabling 'Enable TCP keepalives' and setting a keepalive timer. The Geek Diary has a blog post detailing how to enable this. They also include a picture of the settings you need, I'm not sure if I'm allowed to include that picture on SO (this is my first response!)
Hope this helps.
  • I tried to play around with Second between keepalives. There are no two checkboxes to be selected (Disable Nagle’s Algorithm, Enable TCP Keepalives) in my running version (Release 0.76). It didn't have an effect on dropping. – thermike Mar 30 '22 at 12:30
  • Also searching around i found this link and I folowed the section2 of the answer but didn't have an effect either. – thermike Mar 30 '22 at 12:32
After multiple tries and modifications I think I have reached a stable state where ssh drops something like 1 time in 6 days, and this may be due to outside reasons like current drops or cable test. What I did that stabilized the setup was the following: I added a I2C Bi-Directional Logic Level Converter Module 5V to 3.3V circuit between the rpi and arduino. Although this is not necessary, because the rpi acts as a server in the i2c connection, let me to have a better common ground between the two components. Actually the common ground I was using was displaced after so many reconnections.
thermike
  • 39
Wait wait, Network Packets... Put this Pi on a hub, and your "connecting" PC on it also. Do some of these processes. Run WireShark while doing them. Then you'll have the full network packet log to look at. Don't run more than 2 minutes of WireShark. Trolling all the data it always fun!
IMHO OctoPrint while not a services hog, can be. Why is the Arduino in this system? I've tried almost every model of Pi with OctoPrint. It's happiest in my experiences with a Pi 4b-4GB ... I got mine 2 years ago, when they were affordable. Good luck with your research.
Joel Huebner
  • 115
