Switch Raspberry Hotspot "RaspAP" (wlan0) to a simple Wifi Device via a script
What is missing
    #!/bin/bash
# This script will stop the RASPAP Hotspot (AP+DHP) and will Switch your Raspberry to a WIFI Client
# Be care : Before to do that, be sure that you have the correct SSID in : wpa_supplicant.conf
# Run : bash sap2cl.sh
# First :
# sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
#       ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
#       update_config=1
#       country=FR
#       network={
#        ssid="Freebox-CKL-I"
#        psk="xxxxxxxxx"
echo "Stopping hostapd, dnsmasq & dhcpcd"
sudo systemctl stop hostapd.service
sudo systemctl stop dnsmasq.service
sudo systemctl stop dhcpcd.service
echo "Restart wpa_supplicant"
sudo wpa_supplicant -B -Dnl80211,wext -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
echo "Done."
exit
Nothing happen, after running the script : I can't find the IP address of my Raspberry through a network scanner
  • If you search this site you will find a few posts with similar objectives. I even posted one which didn't require restart - which kind of worked. Whether any of them work is doubtful. Your idea is unlikely to work because it fails to understand how dhcpcd works. I believe it may be possible with systemd.networkd but this requires totally different setup. – Milliways Mar 09 '22 at 10:30
  • So I have certainly to start from the beginning, and not necessarily use RASPAP, but hostapd configuration that makes it easier to switch from client mode to Routed Wireless Access Point mode.. – Christian Klugesherz Mar 09 '22 at 11:05
  • You can try to remove -B and add -d in wpa_supplicant command line to see debug lines. Also, wpa_supplicant not assign an IP address you must use dhclient. dhclient --help and in /etc/dhcp/dhclient.conf you can find config example. 1) start wpa_supplicant with & at the end or add -B, 2) start dhclient. NOTE: also you can create one second wireless interface iw dev wlan0 interface add ap0 type __ap , one for the client (for wpa_supplicant, wlan0), one for the AP (for hostapd, ap0) – Ephemeral Mar 09 '22 at 13:59
Was just having a look through this thread. I created a project a few years ago and wanted to find what has been discussed above, but rather than switching every reboot, I wanted it to connect to the local network if it found it, and if not (when I was out in the field), revert to ad-hoc.(where I could use it as a standalone webserver). I actually found this on another project it has been pretty useful to me, if that is what you need, (and like me, can't code, only follow instructions!) :)
DAvid P
  • While this link may answer the question, it is better to include the essential parts of the answer here and provide the link for reference. Link-only answers can become invalid if the linked page changes. - From Review – Chenmunka Oct 15 '23 at 20:24
Finally I got the solution. The only point is that I need a reboot to switch from Client to AP. But this is not really an issue in my case. However if there could be a solution in the last script I'm openminded
See script : scl2ap.sh
Thanks
Wifi
Activate Wifi in /etc/wpa_supplicant/wpa_supplicant.conf
    update_config=1
    country=FR
    network={
        psk="xxxxxxxxx"
Kill and restart Wifi
sudo pkill wpa_supplicant
sudo wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -B -Dnl80211,wext
Access point:
The Raspberry Pi needs to have the hostapd access point software package installed:
sudo apt-get install hostapd
To create a new configuration file : /etc/hostapd/hostapd.conf Change : country, ssid , wpa_passphrase : to match with yours
    country_code=FR
    interface=wlan0
    ssid=LapemNetwork
    hw_mode=g
    channel=7
    macaddr_acl=0
    auth_algs=1
    ignore_broadcast_ssid=0
    wpa=2
    wpa_passphrase=password
    wpa_key_mgmt=WPA-PSK
    wpa_pairwise=TKIP
    rsn_pairwise=CCMP
Verify that configuration file location in /etc/init.d/hostapd containing is there, if not add. DAEMON_CONF=/etc/hostapd/hostapd.conf
Enable the wireless access point service and set it to start when your Raspberry Pi boots:
sudo systemctl unmask hostapd
sudo systemctl enable hostapd
DHCP Distribution
In order to provide network management services (DNS, DHCP) to wireless clients install dnsmasq
sudo apt-get install dnsmasq
To configure the distribution DHCP IP range we need to configure /etc/dnsmasq.conf At the bottom of the file we need to add the following lines.
    interface=wlan0
    dhcp-range=192.168.0.100,192.168.0.200,12h
activate the dnsmasq service at boot: sudo systemctl enable dnsmasq.service
AP as static
AP needs to have a static address: configured in etc/dhcpcd.conf
Defaut (DHCP) sudo cp /etc/dhcpcd.conf /etc/dhcpcd-dynamic.conf
Static add at the end of the file sudo nano /etc/dhcpcd.conf
    #Static IP
    interface wlan0
        static ip_address=192.168.0.1/24
        nohook wpa_supplicant
sudo cp /etc/dhcpcd.conf /etc/dhcpcd-static.conf
Default mode AP
Command to run to activate AP for next boot
sudo cp  /etc/dhcpcd-static.conf /etc/dhcpcd.conf
SWITCH : AP --> Client : definive
file : sap2cl.sh
Effect is dynamic and definive --> Next start will be as Client mode
#!/bin/bash
# This script will stop Hotspot (AP+DHCP) and will Switch your Raspberry to a WIFI Client (Definitely)
# Effect is dynamic and definive --> Next start will be as Client mode
echo "========================================" echo " Switch from Hotspot (AP+DHP) to Client " echo " Next start will be : Wifi Client mode " echo "========================================" echo " " echo "Stopping hostapd, dnsmasq " sudo systemctl stop hostapd.service sudo systemctl stop dnsmasq.service
echo "Configure Client to recover dhcp" sudo cp /etc/dhcpcd-dynamic.conf /etc/dhcpcd.conf sudo systemctl daemon-reload
echo "Restart wpa_supplicant" sudo pkill wpa_supplicant sleep 2 sudo wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -B -Dnl80211,wext
echo "Done." exit
SWITCH : AP --> Client : Next boot will be as AP
file : sap2clnsap.sh
Effect is dynamic --> Next start will be as AP
#!/bin/bash
# This script will stop Hotspot (AP+DHCP) and will Switch your Raspberry to a WIFI Client (Temporarily)
# Effect is dynamic --> Next start will be as AP
echo "========================================" echo " Switch from Hotspot (AP+DHP) to Client " echo " Next start will be : AP mode " echo "========================================" echo " " echo "Stopping hostapd, dnsmasq " sudo systemctl stop hostapd.service sudo systemctl stop dnsmasq.service
echo "Prepare for next start as AP" sudo systemctl unmask hostapd sudo systemctl enable hostapd sudo systemctl enable dnsmasq.service sudo cp /etc/dhcpcd-static.conf /etc/dhcpcd.conf
echo "Done." exit
SWITCH : Client --> AP : THIS IS NOT DYNAMIC, AND NEEDS A REBOOT
File : scl2ap.sh
#!/bin/bash
# This script will Switch from Client to Hotspot (AP+DHP)
# Run : bash scl2ap.sh
echo "=========================================" echo " Switch from Client to Hotspot (AP+DHP) " echo " THIS IS NOT DYNAMIC, AND NEEDS A REBOOT " echo "=========================================" echo " " echo "Start hostapd, dnsmasq"
sudo systemctl restart dnsmasq.service sudo systemctl restart hostapd.service
echo "Configure AP wit static IP Address" sudo cp /etc/dhcpcd-static.conf /etc/dhcpcd.conf sudo systemctl daemon-reload
echo "A REBOOT is needed here" sudo systemctl unmask hostapd sudo systemctl enable hostapd sudo systemctl enable dnsmasq.service
echo "Done." exit
