I am running Bullseye on an RPi 3. In attempting to run a GNURadio application I get the subject error.
During my investigation I have found several references to this issue on this and other forums.
One of the discussions led me to an FAQ on github stating the following:
"The chances are this is because ‘something’ (such as gedit) has installed mesa which added its own versions of libEGL and libGLESv2. If you run:
$ sudo find / -name libEGL*
$ sudo find / -name libGLESv2*
on the Raspberry Pi you should just get /opt/vc/lib/libEGL.so and /opt/vc/lib/libGLESv2.so if other ones turn up i.e. /usr/lib/arm-linux-gnueabihf/libEGL.so.1 you could try creating symbolic links for them all like this:
$ sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/arm-linux-gnueabihf/libEGL.so
$ sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/arm-linux-gnueabihf/libEGL.so.1
$ sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so
$ sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2
$ sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2"
[END OF GITHUB TEXT]
When I perform the find operation I get the following:
pi@raspberrypi:~ $ sudo find / -name libGLESv2*
find: ‘/run/user/1000/doc’: Permission denied
/usr/lib/chromium-browser/swiftshader/libGLESv2.so
/usr/lib/arm-linux-gnueabihf/libGLESv2.so.2.1.0
/opt/minecraft-pi/lib/brcm/libGLESv2.so
/opt/minecraft-pi/lib/mesa/libGLESv2.so
pi@raspberrypi:~ $ sudo find / -name libEGL*
/usr/lib/chromium-browser/swiftshader/libEGL.so
/usr/lib/arm-linux-gnueabihf/libEGL_mesa.so.0
/usr/lib/arm-linux-gnueabihf/libEGL.so.1.1.0
/usr/lib/arm-linux-gnueabihf/libEGL_mesa.so.0.0.0
/opt/minecraft-pi/lib/brcm/libEGL.so
/opt/minecraft-pi/lib/mesa/libEGL.so
As you can see I don't show the /opt/vc that the FAQ says I should see. My question is then what do I use to perform the symbolic link? Do I use minecraft-pi: either brcm or mesa? Do I use chromium-browser?
Please help as I now am completely blocked from using my GNURadio application which BTW worked well on Jessie.
ldd
, eg.ldd $(which gedit)
will show the ones forgedit
. This is SOP; the use offind
and random guessing is worse than a waste of time, it is libel to lead to some bad decisions, and whoever is advocating it is unlikely to be a source of good advice. – goldilocks Feb 19 '22 at 15:15gnuradio
is not a command (the same thing will happen if you doldd somethingthatdoesntexist
). A glance at this wiki indicates that it is really a suite of tools, some of which may be python scripts (which complicates the issue). You'll need to figure out which of those it is that you are using that fails this way. – goldilocks Feb 19 '22 at 19:55
