-1
I ruined my RPi, by using Python script in rc.local which shutdowns RPi as soon as it starts. Thus I cannot even login or ssh. How could I edit SD card from windows to change that rc.local file?
Ri Di
  • 107
This can not be done on Windows, but it can be fixed on any Linux system (which can be a Pi).
You can repair most such problems on the Pi itself by rebooting to a root shell.
  1. Append init=/bin/sh at the end of cmdline.txt and reboot.
  2. After booting you will be at the prompt in a root shell.
  3. Your root file system is mounted as readonly now, so remount it as read/write mount -n -o remount,rw /
You can then edit files to fix the problem.
  1. Remove init=/bin/sh from cmdline.txt and reboot.
