I have a Pi 4 running Raspberry Pi OS that I use as an Emby server. It's just a fresh install of Raspberry Pi OS with Samba and Emby, nothing else. It has been working fine for months, but yesterday Emby wouldn't start due to a "No space left on device" error.
I checked with df and sure enough there's no space on the internal SD card:
user@Server:/mnt $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 30G 29G 0 100% /
devtmpfs 805M 0 805M 0% /dev
tmpfs 934M 0 934M 0% /dev/shm
tmpfs 934M 11M 924M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 934M 0 934M 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 50M 203M 20% /boot
/dev/sdd1 3.6T 2.5T 1010G 72% /mnt/storage1
/dev/sdc1 3.6T 2.5T 1004G 72% /mnt/storage2
/dev/sdb1 9.1T 5.0T 3.7T 58% /mnt/media2
/dev/sda1 9.1T 5.0T 3.7T 58% /mnt/media1
tmpfs 187M 0 187M 0% /run/user/1000
So what's taking up all the space? I ran du in / to check:
user@Server:/ $ sudo du -sh *
0 bin
50M boot
0 dev
3.9M etc
48K home
0 lib
16K lost+found
4.0K media
15T mnt
240M opt
du: cannot access 'proc/1036/task/1036/fd/4': No such file or directory
du: cannot access 'proc/1036/task/1036/fdinfo/4': No such file or directory
du: cannot access 'proc/1036/fd/3': No such file or directory
du: cannot access 'proc/1036/fdinfo/3': No such file or directory
0 proc
24K root
11M run
0 sbin
4.0K srv
0 sys
32K tmp
1.3G usr
1.5G var
I don't understand the four lines about proc/1036, but otherwise this all looks correct. There's 15 TB in mnt, which is on external drives. And everything else adds up to about 5 GB. So there should be around 25 GB free on the SD card. But there's not.
This question describes a similar problem that was resolved by expanding the fileystem. I definitely expanded the file system when I first set it up. Just in case, I ran sudo raspi-config and expanded it again. No change. So that doesn't seem to be the issue. Another question shows a very similar issue, but with no resolution.
How can I figure out what is taking up all my space?
