I managed to set up hostapd using wifi-ap
via Snap so my Raspberry Pi 4 creates a new Wifi Network Ubuntu
that I can connect to. When I log in to that Raspberry via SSH using the new network, I can successfully do so, and when I ping a server on the internet from within the RPI, it can reach that server.
But when I connect to the Wifi that the Pi creates from my laptop, I don't have any access to the internet.
What am I missing to "bridge" the two interfaces so I can use the Raspberry Pi as a normal access point Wifi > Ethernet?
My /etc/netplan/50-cloud-init.yaml
network:
version: 2
renderer: networkd
ethernets:
eth0:
dhcp4: true
dhcp6: true
my /var/snap/wifi-ap/361/hostapd.conf
interface=wlan0
driver=nl80211
channel=6
macaddr_acl=0
ignore_broadcast_ssid=0
ieee80211n=1
ssid=Ubuntu
auth_algs=1
utf8_ssid=1
hw_mode=g
# DTIM 3 is a good tradeoff between powersave and latency
dtim_period=3
The wmm_* options are needed to enable AMPDU
and get decent 802.11n throughput
UAPSD is for stations powersave
uapsd_advertisement_enabled=1
wmm_enabled=1
wmm_ac_bk_cwmin=4
wmm_ac_bk_cwmax=10
wmm_ac_bk_aifs=7
wmm_ac_bk_txop_limit=0
wmm_ac_bk_acm=0
wmm_ac_be_aifs=3
wmm_ac_be_cwmin=4
wmm_ac_be_cwmax=10
wmm_ac_be_txop_limit=0
wmm_ac_be_acm=0
wmm_ac_vi_aifs=2
wmm_ac_vi_cwmin=3
wmm_ac_vi_cwmax=4
wmm_ac_vi_txop_limit=94
wmm_ac_vi_acm=0
wmm_ac_vo_aifs=2
wmm_ac_vo_cwmin=2
wmm_ac_vo_cwmax=3
wmm_ac_vo_txop_limit=47
wmm_ac_vo_acm=0
Regulatory domain options
Country code set to global
country_code=XX
End reg domain options
wpa=2
wpa_key_mgmt=WPA-PSK
wpa_passphrase=*****************
wpa_pairwise=TKIP
rsn_pairwise=CCMP
my netconfig
output
ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:c4:76:07:d8 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
inet 192.168.8.104 netmask 255.255.255.0 broadcast 192.168.8.255
inet6 fe80::dea6:32ff:fe0d:47b2 prefixlen 64 scopeid 0x20<link>
inet6 fd29:d2c5:be9d::d60 prefixlen 128 scopeid 0x0<global>
inet6 fd29:d2c5:be9d:0:dea6:32ff:fe0d:47b2 prefixlen 64 scopeid 0x0<global>
ether dc:a6:32:0d:47:b2 txqueuelen 1000 (Ethernet)
RX packets 9251 bytes 3761308 (3.7 MB)
TX packets 7765 bytes 1113458 (1.1 MB)
RX packets 23558 bytes 3709615 (3.7 MB)
TX packets 23558 bytes 3709615 (3.7 MB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.60.1 netmask 255.255.255.0 broadcast 0.0.0.0
ether dc:a6:32:0d:47:b3 txqueuelen 1000 (Ethernet)
TX packets 102 bytes 82620 (82.6 KB)
