I have got a new Raspberry Pi, and I am eager to work on it, but I am not able to connect to the network from it.
I connect to the Raspberry Pi using SSH. When I try doing the
apt-get update
apt-get install tightvnc
I get the error
Temporary failure resolving 'mirrordirector.raspbian.org'
It looks like many of them have had this issue. I tried several ways suggested by those who got it working that way.
I checked this link and this link and edited the resolv.conf file. The resolv.conf file was having the line nameserver 10.42.0.1 before I edited it.
I added the lines,
nameserver 8.8.8.8
nameserver 8.8.4.4
I connected to the Raspberry Pi using the IP address 10.42.0.69. I don't think so that should be added to resolv.conf file as well.
I have tried editing the /etc/network/interfaces file as well to set a static IP address, but I reverted it back after I found out that I can also assign a static IP address using this command sudo ifconfig eth0 192.168.x.x netmask 255.255.255.0. I like this one because I didn't have to make the interfaces file dirty.
The /etc/network/interfaces looks like this:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
So, yes, this is a DHCP from a home router.
OS: Raspbian
I cannot ping 8.8.8.8 or any other external IP address. However, I can ping the IP address to my laptop to which I have connected the Raspberry Pi.
I have tried re-flashing the SD card, but I reached nowhere.
ifconfig -aafter a reboot) – ExploWare Mar 12 '14 at 20:59
