Because I'm running a server, I moved my Pi's file directory to a USB device using this tutorial, which means that I'm booting from an SD card, but all of the stuff I need is in a USB drive. How can I back up both my SD card and my USB so that I can save all of my settings if something crashes. Better yet, is there a way to backup my files via FTP or SSH?
Asked
Active
Viewed 710 times
Your server most likely runs headless, remote access is via ssh
USB drive and SD card are both known to your system via fstab. So, it actually doesn't matter what they are, physically.
If you want a simple method with a small footprint, please consider rsync.
Note that rsync
plays nice via ssh, you probably want exactly that to backup your data to another remote machine. Authentification can be realized via ssh-keys.
Klaus-Dieter Warzecha
- 369
- 4
- 12
Could you suggest any tutorial I could follow to accomplish this? I'm more or less a newcomer to linux and I'm not very confident on doing something like this without help. – Alexander Lozada Feb 09 '14 at 18:10
This may help http://raspberrypi.stackexchange.com/questions/13611/using-rsync-to-backup-pi – Milliways Feb 11 '14 at 01:11
