XY-problem
I have a keyboard that consists of two halves. Each half uses 16 pins. The pins in each half are aligned in a 8x8 matrix yielding 64 key presses that can be detected, and two times 64=128 keys in total. I can set a value on GPIO pin 8, and then read out the value on GPIO pin 9 to determine whether the key on the intersection of 8 and 9 is pressed. The values are identical if there is a connection between GPIO pin 8 and 9. A keypress realises such a connection.
Example Code
After using the following script to detect a connection between two GPIO pins (GPIO pin 8 and GPIO pin 9) on a Raspberry Pico:
from machine import Pin
import time
led = Pin(15, Pin.OUT)
output_line= Pin(8, Pin.OUT)
input_line = Pin(9, Pin.IN, Pin.PULL_DOWN)
while True:
time.sleep(2)
if(input_line.value()):
led.toggle()
time.sleep(0.5)
print("connected")
output_line.value(1)
print("set high")
Issue
The pico however does not have 2 times 16 GPIO pins but 26 (25 excluding the led I think). Which means it does not have enough pins for two 8x8 matrices (which require two times 8+8=32 pins). So I am looking for another 7 pins that I can set values to, or read values/connections from on other pins, to get 32 pins on which the two keyboard matrices connections/keypresses can be detected.
Solution Attempts: Software
So I tried setting the value of pin 25 and reading out the value of pin 26, however, that disconnects the Pico when I try to find that connection, for example when I connect GPIO27_A1 to AGND.
Solution Attempt: Software Example
An example I had in mind was: I assume the 3V3 sets some value/voltage, e.g. 3 Volts. I assumed that if I connect the 3V3 pin to a GPIO pin 10, and read out the value of 10, it would be False if it is not connected to 3V3, and True if it is connected to 3V3. If those assumptions are valid, that would grant me another row/pin from which I can read off key presses.
Solution Strategy: Hardware
So I could either buy cables that allow me to connect two jumper cables to a single pin, and then send those pulses/values to the left and right half of the keyboard, (multiplying the signals of the first 8 GPIO pins by two), and using another 16 pins to read out the values.
However, I was having some difficulty in finding single female to double female jumper cables, and thought it would be more elegant to not buy extra material if I can squeeze the functionality out of the board itself.
Hence, I would like to ask: Is it possible to also determine connections*/(logic levels) between non-GPIO pins (and GPIO pins) in some way?
*This assumes that I am aware that there is just a single wire going from one pin to another, meaning, if the values/voltages on two pins is identical (and manually set on 1 of the two), I assume there is a connection.
