I am trying to connect to a U-Blox7 USB GPS sensor, following the steps outlined here. The device is detected, but not receiving GPS data. I am not not in a shielded area.
- Checking that the device is detected:
$ ls /dev/tty*
/dev/tty /dev/tty16 /dev/tty24 /dev/tty32 /dev/tty40 /dev/tty49 /dev/tty57 /dev/tty8
/dev/tty0 /dev/tty17 /dev/tty25 /dev/tty33 /dev/tty41 /dev/tty5 /dev/tty58 /dev/tty9
/dev/tty1 /dev/tty18 /dev/tty26 /dev/tty34 /dev/tty42 /dev/tty50 /dev/tty59 /dev/ttyAMA0
/dev/tty10 /dev/tty19 /dev/tty27 /dev/tty35 /dev/tty43 /dev/tty51 /dev/tty6 /dev/ttyprintk
/dev/tty11 /dev/tty2 /dev/tty28 /dev/tty36 /dev/tty44 /dev/tty52 /dev/tty60 /dev/ttyUSB0
/dev/tty12 /dev/tty20 /dev/tty29 /dev/tty37 /dev/tty45 /dev/tty53 /dev/tty61
/dev/tty13 /dev/tty21 /dev/tty3 /dev/tty38 /dev/tty46 /dev/tty54 /dev/tty62
/dev/tty14 /dev/tty22 /dev/tty30 /dev/tty39 /dev/tty47 /dev/tty55 /dev/tty63
/dev/tty15 /dev/tty23 /dev/tty31 /dev/tty4 /dev/tty48 /dev/tty56 /dev/tty7
I can see the /dev/ttyACM0 folder.
- Verify if the GPS has been bound to this folder.
$ sudo cat /dev/ttyACM0
$GPTXT,01,01,02,u-blox ag - www.u-blox.com*50
$GPTXT,01,01,02,HW UBX-G70xx 00070000 FF7FFFFFo*69
$GPTXT,01,01,02,ROM CORE 1.00 (59842) Jun 27 2012 17:43:52*59
$GPTXT,01,01,02,PROTVER 14.00*1E
$GPTXT,01,01,02,ANTSUPERV=AC SD PDoS SR*20
$GPTXT,01,01,02,ANTSTATUS=OK*3B
$GPTXT,01,01,02,LLC FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFD*2C
$GPTXT,01,01,01,NMEA unknown msg*58
$GPRMC,,V,,,,,,,,,,N*53
$GPVTG,,,,,,,,,N*30
$GPGGA,,,,,,0,00,99.99,,,,,,*48
$GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*30
$GPGSV,1,1,02,15,,,21,17,,,21*79
$GPGLL,,,,,,V,N*64
As can be seen, the sensor isn't getting the GPS values, $GPGGA,,,,,,0,00,99.99,,,,,,*48 (and most other fields) empty. I expect to see these values as in the screenshot below (from the link above).
Using raspberry pi model B+.
EDIT
A further check (after changing location shown the device sending some "unreadable data").
#4�����
x;�|E�
~B}i%�b��'''''''寵b ��;%���Z��b4��A��\��$�s{U��fF'��
#4�����
x;�|E�
~B}S�b=
#4�����
x;�|E�
~B}>ɵb=
#4�����
x;�|E�
~B})��b=
$4�����
x;�|E�
~�b=
$4�����
x;�|E�
~B}9�b^C
