I was in the middle of upgrading to Bullseye from Buster when my SSH session failed, and I couldn't ssh
into the machine anymore. I rebooted it, and now am presented with this problem.
I have attempted --fix-broken
but it just outputs the same thing over and over again. I think I would want to install the baseline version of packages for bullseye
I should be set, I have nothing mission critical going on here, just am unsure how to untangle the currently installed packages.
pi@pihole:~ $ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Correcting dependencies... failed.
The following packages have unmet dependencies:
bsdmainutils : Depends: ncal but it is not installed
libc-bin : Depends: libc6 (< 2.29) but 2.31-13+rpi1+deb11u2 is installed
libc-dev-bin : Depends: libc6 (< 2.29) but 2.31-13+rpi1+deb11u2 is installed
libc6-dbg : Depends: libc6 (= 2.28-10+rpt2+rpi1) but 2.31-13+rpi1+deb11u2 is installed
libc6-dev : Depends: libc6 (= 2.28-10+rpt2+rpi1) but 2.31-13+rpi1+deb11u2 is installed
locales : Depends: libc-bin (> 2.31) but 2.28-10+rpt2+rpi1 is installed
openssh-sftp-server : Depends: openssh-client (= 1:7.9p1-10+deb10u2+rpt1) but 1:8.4p1-5+b1 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
Looking at the policy for libc6
pi@pihole:~ $ apt policy libc6
libc6:
Installed: 2.31-13+rpi1+deb11u2
Candidate: 2.31-13+rpt2+rpi1+deb11u2
Version table:
2.31-13+rpt2+rpi1+deb11u2 500
500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
*** 2.31-13+rpi1+deb11u2 500
500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
100 /var/lib/dpkg/status
And same for libc-bin
pi@pihole:~ $ apt policy libc-bin
libc-bin:
Installed: 2.28-10+rpt2+rpi1
Version table:
*** 2.28-10+rpt2+rpi1 100
Current /etc/apt/sources.list
&& /etc/apt/sources.list.d/raspi.list
pi@pihole:~ $ cat /etc/apt/sources.list
deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
pi@pihole:~ $ cat /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.org/debian/ bullseye main
buster
system? – Seamus Jan 06 '22 at 09:34sudo apt install gcc-8-base
) appeared to do the trick for me" (https://unix.stackexchange.com/a/592703/33071) – John U Aug 02 '23 at 14:55
