I am trying to create a virtual environment that can access GPIO pins. In order to do that, I need access to RPi.GPIO in the environment. I am unable to install that into the virtual environment. I managed to make it work by allowing the environment to have access to system packages, but I would like to avoid that.
I installed the latest clean copy of the Raspbian OS, connected to the internet and ran the following commands.
sudo apt-get update
sudo apt-get full-upgrade
python -m venv venv_sandbox
cd venv_sandbox
pip install rpi.gpio
The last command results in a very long error.
Installing collected packages: rpi.gpio
Running setup.py install for rpi.gpio ... error
ERROR: Command errored out with exit status 1:
command: /home/pi/test_venv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/setup.py'"'"'; __file__='"'"'/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-vwjkwb7k/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/test_venv/include/site/python3.9/rpi.gpio
cwd: /tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/
Complete output (87 lines):
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.9
creating build/lib.linux-armv7l-3.9/RPi
copying RPi/__init__.py -> build/lib.linux-armv7l-3.9/RPi
creating build/lib.linux-armv7l-3.9/RPi/GPIO
copying RPi/GPIO/__init__.py -> build/lib.linux-armv7l-3.9/RPi/GPIO
running build_ext
building 'RPi._GPIO' extension
creating build/temp.linux-armv7l-3.9
creating build/temp.linux-armv7l-3.9/source
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/home/pi/test_venv/include -I/usr/include/python3.9 -c source/c_gpio.c -o build/temp.linux-armv7l-3.9/source/c_gpio.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/home/pi/test_venv/include -I/usr/include/python3.9 -c source/common.c -o build/temp.linux-armv7l-3.9/source/common.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/home/pi/test_venv/include -I/usr/include/python3.9 -c source/constants.c -o build/temp.linux-armv7l-3.9/source/constants.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/home/pi/test_venv/include -I/usr/include/python3.9 -c source/cpuinfo.c -o build/temp.linux-armv7l-3.9/source/cpuinfo.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/home/pi/test_venv/include -I/usr/include/python3.9 -c source/event_gpio.c -o build/temp.linux-armv7l-3.9/source/event_gpio.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/home/pi/test_venv/include -I/usr/include/python3.9 -c source/py_gpio.c -o build/temp.linux-armv7l-3.9/source/py_gpio.o
source/py_gpio.c: In function ‘PyInit__GPIO’:
source/py_gpio.c:1046:4: warning: ‘PyEval_ThreadsInitialized’ is deprecated [-Wdeprecated-declarations]
1046 | if (!PyEval_ThreadsInitialized())
In file included from /usr/include/python3.9/Python.h:145,
from source/py_gpio.c:23:
/usr/include/python3.9/ceval.h:129:36: note: declared here
129 | Py_DEPRECATED(3.9) PyAPI_FUNC(int) PyEval_ThreadsInitialized(void);
source/py_gpio.c:1047:7: warning: ‘PyEval_InitThreads’ is deprecated [-Wdeprecated-declarations]
1047 | PyEval_InitThreads();
/usr/include/python3.9/ceval.h:130:37: note: declared here
130 | Py_DEPRECATED(3.9) PyAPI_FUNC(void) PyEval_InitThreads(void);
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/home/pi/test_venv/include -I/usr/include/python3.9 -c source/py_pwm.c -o build/temp.linux-armv7l-3.9/source/py_pwm.o
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/home/pi/test_venv/include -I/usr/include/python3.9 -c source/soft_pwm.c -o build/temp.linux-armv7l-3.9/source/soft_pwm.o
arm-linux-gnueabihf-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -g -fwrapv -O2 -Wl,-z,relro -g -fwrapv -O2 -g -ffile-prefix-map=/python3.9-3.9.2=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 build/temp.linux-armv7l-3.9/source/c_gpio.o build/temp.linux-armv7l-3.9/source/common.o build/temp.linux-armv7l-3.9/source/constants.o build/temp.linux-armv7l-3.9/source/cpuinfo.o build/temp.linux-armv7l-3.9/source/event_gpio.o build/temp.linux-armv7l-3.9/source/py_gpio.o build/temp.linux-armv7l-3.9/source/py_pwm.o build/temp.linux-armv7l-3.9/source/soft_pwm.o -o build/lib.linux-armv7l-3.9/RPi/_GPIO.cpython-39-arm-linux-gnueabihf.so
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:41: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:40: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:39: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:38: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:37: first defined here
blabla lots of error logs that I can't post because number of characters are limited
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:34: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/py_pwm.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/common.h:33: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/soft_pwm.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/soft_pwm.c:28: multiple definition of `threads'; build/temp.linux-armv7l-3.9/source/event_gpio.o:/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/source/event_gpio.c:60: first defined here
collect2: error: ld returned 1 exit status
error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
ERROR: Command errored out with exit status 1: /home/pi/test_venv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/setup.py'"'"'; file='"'"'/tmp/pip-install-erugpti2/rpi-gpio_f96cc890e48a4d1cbcc15f9738db26ab/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' install --record /tmp/pip-record-vwjkwb7k/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/test_venv/include/site/python3.9/rpi.gpio Check the logs for full command output.
As you can see in the first line of the error message, it said package wheel
is not installed so I tried installing that.
pip install wheel
The error here seems to be divided into 2 sections
Building wheels for collected packages: rpi.gpio
Building wheel for rpi.gpio (setup.py) ... error
command: /home/pi/test_venv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/setup.py'"'"'; __file__='"'"'/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-xwlaa_zg
cwd: /tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/
running bdist_wheel
running build
running build_py
creating build
running build_ext
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/source/common.h:41: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/source/common.h:40: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/source/common.h:39: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/constants.o:/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-armv7l-3.9/source/common.o:/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/source/common.h:38: first defined here
gpio_393bfb7d7ed344aea4d895fd7488d832/source/common.h:33: first defined here
/usr/bin/ld: build/temp.linux-armv7l-3.9/source/soft_pwm.o:/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/source/soft_pwm.c:28: multiple definition of `threads'; build/temp.linux-armv7l-3.9/source/event_gpio.o:/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/source/event_gpio.c:60: first defined here
ERROR: Failed building wheel for rpi.gpio
This is then followed by
Running setup.py clean for rpi.gpio
Failed to build rpi.gpio
command: /home/pi/test_venv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/setup.py'"'"'; __file__='"'"'/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-g4kccf4m/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/test_venv/include/site/python3.9/rpi.gpio
running install
running build
running build_py
creating build
running build_ext
ERROR: Command errored out with exit status 1: /home/pi/test_venv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/setup.py'"'"'; file='"'"'/tmp/pip-install-397g_s4d/rpi-gpio_393bfb7d7ed344aea4d895fd7488d832/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' install --record /tmp/pip-record-g4kccf4m/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/test_venv/include/site/python3.9/rpi.gpio Check the logs for full command output.
Notes:
- Running pip freeze does not display wheel as installed after I installed it with pip
- both python and pip are using version 3
- everything works (the scripts using GPIO pins) if I set the venv to use system packages
Is there a way to install RPi.GPIO on virtual environments? There are a lot of answers suggesting it can be, but none discuss the issue that I'm having.
If there isn't, is there a way to set the virtual environment to just use this specific system package? I would prefer not to give it access to everything?
