In order to clarify my question -
cat /proc/device-tree/model:
Raspberry Pi 3 Model B Rev 1.2
cat /etc/os-release:
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
apache2 -v:
Server version: Apache/2.4.51 (Raspbian)
Server built: 2021-10-07T17:49:44
mysql -V:
mysql Ver 15.1 Distrib 10.5.12-MariaDB, for debian-linux-gnueabihf (armv7l) using EditLine wrapper
ip r | grep default:
default via 192.168.1.254 dev wlan0 proto dhcp src 192.168.1.76 metric 303
sudo nano /etc/resolv.conf:
# Generated by resolvconf
nameserver 192.168.1.254
I hope I have generated the necessary information you need to assist me. I am new to this, so I looked-up those commands. I have two SD cards, but only one Raspberry Pi 3. Above is what I have installed on one SD card. The issue I'm having is I have another SD card that I plan on using - installing the same above, but when I go to install everything - then the IP address is still the same:
192.168.1.76
I am wanting the second SD card to be something like:
192.168.1.46
So, when I swap out the SD cards, then the local IP address is already changed. Is this even possible?
Thank you for your time.
EDIT:
ip a && ip r:
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:82:72:4d brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:d7:27:18 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.76/24 brd 192.168.1.255 scope global dynamic noprefixroute wlan0
valid_lft 56330sec preferred_lft 45530sec
inet6 2600:1700:3b01:2a70:b648:20cf:994:626/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 3208sec preferred_lft 3208sec
inet6 fe80::cdc9:5bc:9b4e:7f4b/64 scope link
192.168.1.0/24 dev wlan0 proto dhcp scope link src 192.168.1.76 metric 303
ip a && ip r
. I wasn't clear - I'm not necessary wanting a unique address for each card. I'm just wanting to make sure they're different local addresses regardless what the router assigns.. Maybe I'm doing all of this incorrect - I have two websites as a hobby, and I want each SD card to have to have its own website data. – Sanders Dec 23 '21 at 00:34
