I seem to have lost "Wireless & Wired Network" and "Bluetooth" applets for lxpanel after a Buster->Bullseye upgrade. The relevant packages (lxplug-network and lxplug-bluetooth) appears to be installed:
pi@raspberrypi:~ $ dpkg -l | grep lxpanel
ii lxpanel 0.10.1-2 armhf LXDE panel
ii lxpanel-data 0.10.1-2 all LXDE panel (data files)
ii lxplug-bluetooth 0.21 armhf Bluetooth plugin for lxpanel
ii lxplug-cputemp 0.6 armhf CPU temperature plugin for lxpanel
ii lxplug-ejecter 0.15 armhf Ejecter plugin for lxpanel
ii lxplug-magnifier 0.6 armhf Magnifier plugin for lxpanel
ii lxplug-network 0.24 armhf Network plugin for lxpanel
ii lxplug-ptbatt 0.14 armhf Battery monitor plugin for lxpanel
ii lxplug-volumepulse 0.5 armhf PulseAudio controller plugin for lxpanel
However, when I click on "Add / Remove Panel Items" menu, I don't see them in the list.
The relevant services (dhcpcd and bluetooth) are up and running:
pi@raspberrypi:~ $ service bluetooth status
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2021-11-08 22:16:08 CET; 10h ago
Docs: man:bluetoothd(8)
Main PID: 584 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4915)
CPU: 106ms
CGroup: /system.slice/bluetooth.service
└─584 /usr/libexec/bluetooth/bluetoothd
pi@raspberrypi:~ $ service dhcpcd status
● dhcpcd.service - dhcpcd on all interfaces
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2021-11-08 22:16:05 CET; 10h ago
Process: 375 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=0/SUCCESS)
Main PID: 425 (dhcpcd)
Tasks: 2 (limit: 4915)
CPU: 16.272s
CGroup: /system.slice/dhcpcd.service
├─425 /sbin/dhcpcd -q -b
└─588 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
pi@raspberrypi:~ $ iwconfig wlan0
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
pi@raspberrypi:~ $ bluetoothctl scan on
Discovery started
[CHG] Controller AA:AA:AA:AA:AA:AA Discovering: yes
[NEW] Device 51:81:EA:67:17:47 51-81-EA-67-17-47
[CHG] Device 51:81:EA:67:17:47 RSSI: -45
[CHG] Device 51:81:EA:67:17:47 RSSI: -62
Did I install the wrong packages, or is there a configuration for lxpanel that I need to apply?
