I'm trying a solution that can change or connect to a new Wi-Fi network with a Python script. After executing the code below that changes the content of 'wpa_supplicant.conf', the change of the file works by inspecting the file with sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
. But after rebooting the Pi to get it to connect to the new network, the Pi couldn't connect to any networks since then.
SSID = input('Enter SSID: ')
password = input("Enter password: ")
with open('/etc/wpa_supplicant/wpa_supplicant.conf', 'w') as file:
content =
"country = MY\n" +
"ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev\n" +
"network={\n" +
'\tssid="' + SSID + '"\n' +
'\tpsk="' + password + '"\n' +
"\tkey_mgmt=WPA-PSK\n" +
file.write(content)
When executing the sudo iwlist wlan0 scan
command line, I got an error of
wlan0 interface doesn't support scanning network is down
"Network is down" was removed after executing ifconfig wlan0 up
. But the error still shows "wlan0 interface doesn't support scanning" when I execute sudo iwlist wlan0 scan
There are no soft or hard blocks seen for Wireless LAN when executing rfkill list
The only way I could think of solving this issue was to reformat and reinstall Raspbian, but I've spent countless hours setting up the OpenCV environment and other third-party libraries, and I don't want to go through that tedious setup process again. Is there any other way?
wpa_supplicant
manually? It provides feedback that almost certainly would explain the issue. – goldilocks Oct 26 '22 at 12:46journalctl -xe
to check the logs. – LilData777 Feb 23 '23 at 15:44
