I would like to know how to access the raspberry pi using only the usb cable used to power it.
Is there a way to setup an IP connection through the micro USB port it like we do with firewire equipment?
The setup I would like to achieve:
  • connect the raspberry pi to my laptop with the USB cable.
  • connect to all the IP services on the raspberry pi without any other wires.
Is it possible?
Coyote
  • 462
No.
The micro USB power connection does not provide any data connection. You could back-power the Pi with one of the other USB data ports, but at the risk of frying your Raspberry Pi. You can read more about this in an article I wrote about powering a Raspberry Pi.
Additionally, there isn't any way to use IP protocol over USB that I know of. At a minimum, you would need to run an ethernet cord from your laptop to your Raspberry Pi or add a wifi dongle to your raspberry pi in combination with a wireless router.
Alex Glover
  • 191
