I used the included SD card to install my raspbian (Buster, I think) on a 32GB card. For some reason the card filled up (that will be a question for another day), so I copied an image of the card to a 256GB card (using dd
on a Mac). But the filesystem still reports the card is almost full. Here's the df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 27G 25G 896M 97% /
devtmpfs 3.8G 0 3.8G 0% /dev
tmpfs 3.9G 377M 3.5G 10% /dev/shm
tmpfs 3.9G 8.7M 3.9G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/loop0 92M 92M 0 100% /snap/qbittorrent-arnatious/43
/dev/loop1 46M 46M 0 100% /snap/core18/2067
/dev/loop2 92M 92M 0 100% /snap/qbittorrent-arnatious/73
/dev/loop3 46M 46M 0 100% /snap/core18/2072
/dev/loop5 66M 66M 0 100% /snap/gtk-common-themes/1515
/dev/loop4 65M 65M 0 100% /snap/gtk-common-themes/1514
/dev/loop6 46M 46M 0 100% /snap/core18/2001
/dev/mmcblk0p6 253M 49M 204M 20% /boot
tmpfs 788M 8.0K 788M 1% /run/user/1000
/dev/sda2 1.9T 1.1T 792G 58% /media/pi/SYD_STUFF
So I ran sudo raspi-config
and tried expanding the usable space, but it said it couldn't help me because it looked like I had used NOOBS.
Your partition layout is not currently supported by this tool. You are probably using NOOBS, in which case your root filesystem is already expanded anyway.
And yet, the rPi sees the 256G. Here's the sudo fdisk -l
Disk /dev/mmcblk0: 238.3 GiB, 255869321216 bytes, 499744768 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xd5282710
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 2048 4978515 4976468 2.4G e W95 FAT16 (LBA)
/dev/mmcblk0p2 4978516 62333951 57355436 27.4G 5 Extended
/dev/mmcblk0p5 4980736 5046269 65534 32M 83 Linux
/dev/mmcblk0p6 5046272 5570557 524286 256M c W95 FAT32 (LBA)
/dev/mmcblk0p7 5570560 62333951 56763392 27.1G 83 Linux
So, how do I get the rPi to recognize and use the entire 256G card?
Thanks for your help.
