I have an RPi 3 running Raspbian 10 (Lite, headless). It is connected to my LAN via eth0 which is working fine.
Now I need to also connect the RPi to a PLC with very limited configuration options (basically: either DHCP client or fixed IP). I plugged in a USB Ethernet adapter, which shows up as eth1, and I am trying to configure a connection with fixed IP addresses.
Some background, as requested in the comments: a PLC is a Programmable Logic Controller, a device commonly used in industrial control applications. It doesn't really matter, the main point is that it is closed source and I have very limited configuration options: I can set it to use DHCP for IP configuration (i.e. as a DHCP client - it doesn't have a server), or assign a fixed IP and netmask.
Here is an attempt to depict the situation with ASCII graphics:
PLC (fixed IP 192.168.60.2; alternative: DHCP client)
v eth1 (fixed IP 192.168.60.1)
RPi
^ eth0 (DHCP client, using default dhcpcd config)
| LAN with DHCP server + gateway to internet
I configured the PLC to use 192.168.60.2 (fixed IP) and added the following lines to /etc/dhcpcd.conf
interface eth1
inform 192.168.60.1/24
ifconfig
shows that eth1 does indeed get 192.168.60.1
, but I can still not reach the PLC at 192.168.60.2
I suspect that messages to 192.168.60.2
are not routed to eth1:
pi@raspberrypi:~$ route
Kernel IP routing table
default 192.168.0.1 0.0.0.0 UG 202 0 0 eth0
192.168.0.0 0.0.0.0 255.255.255.0 U 202 0 0 eth0
pi@raspberrypi:~$
Manually adding a route fixes the problem:
pi@raspberrypi:~$ sudo route add -net 192.168.60.0 netmask 255.255.255.0 dev eth1
192.168.60.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
pi@raspberrypi:~$ ping 192.168.60.2
PING 192.168.60.2 (192.168.60.2) 56(84) bytes of data.
64 bytes from 192.168.60.2: icmp_seq=1 ttl=255 time=10.6 ms
64 bytes from 192.168.60.2: icmp_seq=2 ttl=255 time=2.23 ms
Is this the right way to do this, and if so, how do I automate this? Is there a better way, maybe by adding something to dhcpcd.conf
One possible alternative would be to run a DHCP server on eth1 on the RPi, and configure the PLC as a DHCP client. The challenge would then be to make sure that the PLC always gets the same IP address, even if I replace it with a different PLC (different MAC address). Note: there will always be only one PLC; this is a point-to-point connection.
The reason why I made this a point-to-point connection separate from the LAN, is that the connection with the PLC needs to work even if there is no LAN (network down or misconfigured). I have very little control over the LAN, and the connection to the PLC needs to be very reliable.
PLC
- what is that exactly? Do you meaneither
- orneither
? – Seamus Jun 17 '21 at 19:17192.168.0.0
network is not the network used by your LAN - is that correct? – Seamus Jun 17 '21 at 20:11dhcpcd.conf
, eth1 does not get configured at all. – ygramoel Jun 18 '21 at 07:24
