-1
my problem is that my wifi is only getting an IP address if ethernet cable is also plugged in. I have checked many sides, but the solution below is not working. (funny thing, I have reinstalled this pi, and before this, this problem was not present)
Maybe Have you any idea how to fix this?
RETTY_NAME="Raspbian GNU/Linux 10 (buster)"
pi@raspberrypi:~ $ more /etc/dhcpcd.conf | grep -v # hostname clientid persistent option rapid_commit option domain_name_servers, domain_name, domain_search, host_name option classless_static_routes option interface_mtu require dhcp_server_identifier slaac private allow-hotplug eth0 #(or with wlan0) auto wlan0 #(or without) interface wlan0 static ip_address=192.168.178.99/24 static routers=192.168.178.1 static domain_name_servers=8.8.8.8 8.8.4.4
pi@raspberrypi:~ $ more /etc/wpa_supplicant/wpa_supplicant.conf ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 country=DE network={ ssid="xxxxxx" psk="xxxxxxx" }
/edit
I have no access to the device when this problem happens
It’s plain simple direct local lan connection
Update
so i just have found out that the PI is getting the right ip, and my pc is getting the arp entry but the communication with the pi is not possible
1v4n
If someone is interested- that problem was that the pi have even not booted without the cable
And it was caused due too a headless static ip entry Inside cmdline.txt - which I have used right before the first boot
1v4n
