I followed this tutorial to set my RPi 4B up. In my basement, I have my RPi connected via cable and want to bridge a new WiFi AP (as in the last part of that post above).
The first time, everything worked fine, I was able to connect to my RPi Wifi network with my phone (or other devices) and had an address assigned by the DHCP server on my router/modem.
After a few restarts and/or after docker installation, I can't connect anymore. Android phones are stuck at "Obtaining IP address" and another computer connects, but doesn't get an IP anymore (logs are indicating that DHCP has not returned an address).
I am able to ping/curl public websites on the RPi (though it seems I have to go through the bridge via ping -I br0 -c3 google.com
(-I eth0
doesn't work)).
How can I debug this?
I tried multiple restarts, restarting the services, all to no avail.
Edit: I set up my RPi to have a DNS server (pihole via docker). In order for other docker containers to use that one I changed the system's dns entries, so that I have:
➜ ~ cat /etc/resolv.conf
nameserver 192.168.0.30
nameserver 192.168.0.1
search hitronhub.home
I'm not sure, but those DNS entries should not affect DHCP on the bridge, right? I think it's more related to installing docker (or something else).
Here are a few information:
➜ ~ sudo cat /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
country=ca
update_config=1
app_scan=1
network={
ssid="Basement"
mode=2
frequency=5220
#key_mgmt=NONE # uncomment this for an open hotspot
# delete next 3 lines if key_mgmt=NONE
key_mgmt=WPA-PSK
proto=RSN WPA
psk="*pw*"
➜ ~ ifconfig
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.30 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::d0d9:e2ff:fe3d:699a prefixlen 64 scopeid 0x20<link>
inet6 fd00:a84e:3f6c:9322:d0d9:e2ff:fe3d:699a prefixlen 64 scopeid 0x0<global>
ether d2:d9:e2:3d:69:9a txqueuelen 1000 (Ethernet)
RX packets 79139 bytes 5225897 (5.2 MB)
RX errors 0 dropped 23748 overruns 0 frame 0
TX packets 11782 bytes 1277671 (1.2 MB)
br-bb564efd3146: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.20.0.1 netmask 255.255.0.0 broadcast 172.20.255.255
inet6 fe80::42:2eff:fed1:d618 prefixlen 64 scopeid 0x20<link>
ether 02:42:2e:d1:d6:18 txqueuelen 0 (Ethernet)
RX packets 4470 bytes 412507 (412.5 KB)
TX packets 4454 bytes 462973 (462.9 KB)
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:9a:8c:47:de txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
ether dc:a6:32:9b:6e:cf txqueuelen 1000 (Ethernet)
RX packets 112304 bytes 21691931 (21.6 MB)
TX packets 11842 bytes 1281443 (1.2 MB)
RX packets 91 bytes 6848 (6.8 KB)
TX packets 91 bytes 6848 (6.8 KB)
veth1032cc9: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::2821:79ff:fe14:af4a prefixlen 64 scopeid 0x20<link>
ether 2a:21:79:14:af:4a txqueuelen 0 (Ethernet)
RX packets 907 bytes 272091 (272.0 KB)
TX packets 924 bytes 128079 (128.0 KB)
veth19ee85a: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::7c0e:acff:fe85:96ac prefixlen 64 scopeid 0x20<link>
ether 7e:0e:ac:85:96:ac txqueuelen 0 (Ethernet)
TX packets 39 bytes 2914 (2.9 KB)
veth89ca666: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::5cac:a7ff:fe80:bcb1 prefixlen 64 scopeid 0x20<link>
ether 5e:ac:a7:80:bc:b1 txqueuelen 0 (Ethernet)
RX packets 905 bytes 126613 (126.6 KB)
TX packets 928 bytes 273641 (273.6 KB)
vethb7b11d8: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::6013:bcff:fe15:378a prefixlen 64 scopeid 0x20<link>
ether 62:13:bc:15:37:8a txqueuelen 0 (Ethernet)
TX packets 42 bytes 3108 (3.1 KB)
vethf67b8c4: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::48ed:15ff:fe94:4f78 prefixlen 64 scopeid 0x20<link>
ether 4a:ed:15:94:4f:78 txqueuelen 0 (Ethernet)
RX packets 4469 bytes 475045 (475.0 KB)
TX packets 4483 bytes 464811 (464.8 KB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::dea6:32ff:fe9b:6ed0 prefixlen 64 scopeid 0x20<link>
ether dc:a6:32:9b:6e:d0 txqueuelen 1000 (Ethernet)
RX packets 439 bytes 93244 (93.2 KB)
TX packets 15318 bytes 1517332 (1.5 MB)
➜ ~ sudo networkctl status
● State: routable
Address: 192.168.0.30 on br0
172.17.0.1 on docker0
172.20.0.1 on br-bb564efd3146
fd00:a84e:3f6c:9322:d0d9:e2ff:fe3d:699a on br0
fe80::dea6:32ff:fe9b:6ed0 on wlan0
fe80::d0d9:e2ff:fe3d:699a on br0
fe80::42:2eff:fed1:d618 on br-bb564efd3146
fe80::5cac:a7ff:fe80:bcb1 on veth89ca666
fe80::2821:79ff:fe14:af4a on veth1032cc9
fe80::48ed:15ff:fe94:4f78 on vethf67b8c4
fe80::6013:bcff:fe15:378a on vethb7b11d8
fe80::7c0e:acff:fe85:96ac on veth19ee85a
Gateway: 192.168.0.1 (Hitron Technologies. Inc) on br0
DNS: 192.168.0.1
Search Domains: hitronhub.home
Jun 09 05:34:41 rpi systemd-networkd[20792]: veth89ca666: Gained IPv6LL
Jun 09 05:34:41 rpi systemd-networkd[20792]: br-bb564efd3146: Gained IPv6LL
Jun 09 05:34:41 rpi systemd-networkd[20792]: br0: Gained IPv6LL
Jun 09 05:34:41 rpi systemd-networkd[20792]: wlan0: Gained IPv6LL
Jun 09 05:34:41 rpi systemd-networkd[20792]: Enumeration completed
Jun 09 05:34:41 rpi systemd[1]: Started Network Service.
Jun 09 05:34:41 rpi systemd-networkd[20792]: br0: netdev exists, using existing without changing its parameters
Jun 09 05:34:41 rpi systemd[1]: Starting Wait for Network to be Configured...
Jun 09 05:34:41 rpi systemd[1]: Finished Wait for Network to be Configured.
Jun 09 05:34:42 rpi systemd-networkd[20792]: br0: DHCPv4 address 192.168.0.30/24 via 192.168.0.1
➜ ~ route -n
Kernel IP routing table
0.0.0.0 192.168.0.1 0.0.0.0 UG 1024 0 0 br0
172.17.0.0 0.0.0.0 255.255.0.0 U 0 0 0 docker0
172.20.0.0 0.0.0.0 255.255.0.0 U 0 0 0 br-bb564efd3146
192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
192.168.0.1 0.0.0.0 255.255.255.255 UH 1024 0 0 br0
➜ ~ sudo networkctl status br0
● 4: br0
Link File: /usr/lib/systemd/network/99-default.link
Network File: /etc/systemd/network/12-br0_up.network
Type: bridge
State: routable (configured)
Driver: bridge
HW Address: d2:d9:e2:3d:69:9a
MTU: 1500 (min: 68, max: 65535)
QDisc: noqueue
IPv6 Address Generation Mode: eui64
Forward Delay: 15s
Hello Time: 2s
Max Age: 20s
Ageing Time: 5min
[0m Priority: 32768
STP: no
Multicast IGMP Version: 2
Cost: 2000
Port State: disabled
Queue Length (Tx/Rx): 1/1
Auto negotiation: no
Speed: 1Gbps
Address: 192.168.0.30 (DHCP4 via 192.168.0.1)
DNS: 192.168.0.1
DHCP4 Client ID: IAID:0x767f1b5a/DUID
DHCP6 Client IAID: 0x767f1b5a
DHCP6 Client DUID: DUID-EN/Vendor:0000ab11b181b51f9e96a95a0000
Jun 09 02:19:25 rpi systemd-networkd[1649]: br0: netdev ready
Jun 09 02:19:25 rpi systemd-networkd[1649]: br0: Link UP
Jun 09 02:19:29 rpi systemd-networkd[1649]: br0: Gained carrier
Jun 09 02:19:29 rpi systemd-networkd[1649]: br0: DHCPv4 address 192.168.0.30/24 via 192.168.0.1
Jun 09 02:19:31 rpi systemd-networkd[1649]: br0: Gained IPv6LL
Jun 09 05:34:41 rpi systemd-networkd[1649]: br0: DHCPv6 lease lost
Jun 09 05:34:41 rpi systemd-networkd[20792]: br0: netdev ready
Let me know if you need more information, I'll amend this question.
Please don't suggest hostapd, unless the tutorial is totally out-of-date and should not be used anymore.
