I am Raspberry Pi (3B) and the Pi converted wireless access point using Setting up a Raspberry Pi as an access point - the easy way and wlan0 works well. I repeated the process for wlan1 (USB adapter) as suggested by How to create two WiFi Access Points with a single Raspberry Pi with usb adaptor. When reboot wlan1 works but wlan0 stops working. The error message is very strange. When I am only using wlan0, it works perfectly but I got following results when both wlan0 and wlan1 connected. Status of both wlan1 and wlan0 are as follows
pi@raspberrypi:~ $ systemctl status wpa_supplicant@wlan1.service
● wpa_supplicant@wlan1.service - WPA supplicant daemon (interface-specific version)
   Loaded: loaded (/lib/systemd/system/wpa_supplicant@.service; enabled; vendor preset: enabled)
   Active: active (running) since Sun 2021-05-30 14:30:30 AEST; 27min ago
 Main PID: 305 (wpa_supplicant)
   CGroup: /system.slice/system-wpa_supplicant.slice/wpa_supplicant@wlan1.service
           └─305 /sbin/wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant-wlan1.conf -Dnl80211,wext -iwlan1
May 30 14:30:30 raspberrypi systemd[1]: Started WPA supplicant daemon (interface-specific version). May 30 14:30:30 raspberrypi wpa_supplicant[305]: Successfully initialized wpa_supplicant May 30 14:30:32 raspberrypi wpa_supplicant[305]: wlan1: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=AU May 30 14:30:33 raspberrypi wpa_supplicant[305]: Failed to create interface mon.wlan1: -95 (Operation not supported) May 30 14:30:33 raspberrypi wpa_supplicant[305]: wlan1: Could not connect to kernel driver May 30 14:30:33 raspberrypi wpa_supplicant[305]: Using interface wlan1 with hwaddr b8:27:eb:7e:78:7a and ssid "RPi1" May 30 14:30:33 raspberrypi wpa_supplicant[305]: wlan1: interface state UNINITIALIZED->ENABLED May 30 14:30:33 raspberrypi wpa_supplicant[305]: wlan1: AP-ENABLED May 30 14:30:33 raspberrypi wpa_supplicant[305]: wlan1: CTRL-EVENT-CONNECTED - Connection to b8:27:eb:7e:78:7a completed [id=0 id_str=]
pi@raspberrypi:~ $ systemctl status wpa_supplicant@wlan0.service ● wpa_supplicant@wlan0.service - WPA supplicant daemon (interface-specific version) Loaded: loaded (/lib/systemd/system/wpa_supplicant@.service; enabled; vendor preset: enabled) Active: active (running) since Sun 2021-05-30 15:40:12 AEST; 26s ago Main PID: 2586 (wpa_supplicant) CGroup: /system.slice/system-wpa_supplicant.slice/wpa_supplicant@wlan0.service └─2586 /sbin/wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant-wlan0.conf -Dnl80211,wext -iwlan0
May 30 15:40:12 raspberrypi systemd[1]: Started WPA supplicant daemon (interface-specific version). May 30 15:40:12 raspberrypi wpa_supplicant[2586]: Successfully initialized wpa_supplicant May 30 15:40:12 raspberrypi wpa_supplicant[2586]: nl80211: Could not configure driver mode May 30 15:40:12 raspberrypi wpa_supplicant[2586]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0 May 30 15:40:12 raspberrypi wpa_supplicant[2586]: rfkill: Cannot get wiphy information May 30 15:40:12 raspberrypi wpa_supplicant[2586]: ioctl[SIOCSIWAP]: Operation not permitted May 30 15:40:12 raspberrypi wpa_supplicant[2586]: ioctl[SIOCSIWENCODEEXT]: Invalid argument May 30 15:40:13 raspberrypi wpa_supplicant[2586]: wlan0: Driver does not support AP mode May 30 15:40:13 raspberrypi wpa_supplicant[2586]: wlan0: Driver does not support AP mode
The status of systemd-networkd.service
pi@raspberrypi:~ $ systemctl status systemd-networkd.service
● systemd-networkd.service - Network Service
   Loaded: loaded (/lib/systemd/system/systemd-networkd.service; enabled; vendor preset: enabled)
   Active: active (running) since Sun 2021-05-30 14:30:28 AEST; 29min ago
     Docs: man:systemd-networkd.service(8)
 Main PID: 142 (systemd-network)
   Status: "Processing requests..."
   CGroup: /system.slice/systemd-networkd.service
           └─142 /lib/systemd/systemd-networkd
May 30 14:30:28 raspberrypi systemd-networkd[142]: Enumeration completed May 30 14:30:28 raspberrypi systemd[1]: Started Network Service. May 30 14:30:29 raspberrypi systemd-networkd[142]: eth0: IPv6 enabled for interface: Success May 30 14:30:29 raspberrypi systemd-networkd[142]: wlan0: IPv6 enabled for interface: Success May 30 14:30:31 raspberrypi systemd-networkd[142]: eth0: Gained carrier May 30 14:30:33 raspberrypi systemd-networkd[142]: wlan1: Gained carrier May 30 14:30:33 raspberrypi systemd-networkd[142]: eth0: Gained IPv6LL May 30 14:30:34 raspberrypi systemd-networkd[142]: wlan1: Gained IPv6LL May 30 14:30:36 raspberrypi systemd-networkd[142]: eth0: DHCPv4 address 10.0.0.23/24 via 10.0.0.138 May 30 14:30:47 raspberrypi systemd-networkd[142]: wlan1: Configured
When I added wlan1, wlan0 stops working, why? I really appreciate any help.
Raj
  • The error message is very strange - which error message do you find "strange" - why is it "strange"? – Jaromanda X May 30 '21 at 08:10
  • Sorry for unclear question. If you look on the status of the status of wpa_supplicant@wlan0.service, it says wlan0: Driver does not support AP mode but it was running well when I ran only wlan0. Therefore, I find it is strange. you will more details on status output. Thank you. – Raj May 30 '21 at 20:41
  • looks like wlan1 is the onboard wifi from the MAC address b8:27:eb:7e:78:7a - perhaps the USB device on wlan0 doesn't support AP mode - what is your USB wifi device? – Jaromanda X May 30 '21 at 23:04
  • Yes you are right MAC address is belongs to onboard wifi but it shows SSID of wlan1 not wlan0 and therefore, I am confused. I am using TP-LINK WN725N as USB wifi device and the following link says it is working with RPi. https://elinux.org/RPi_USB_Wi-Fi_Adapters – Raj May 31 '21 at 01:30
  • obviously when you plug in a USB wifi dongle, the onboard is becoming wlan1 ... you say you have a WN725N - but the table doesn't show one of those at all, so it may well not support AP mode ... can you share the vendorID/productID of that adapter (use lsusb) - oh, wait, there's notes about it later ... is it a v1 or v2? – Jaromanda X May 31 '21 at 01:39
  • Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter. I think it is v2. – Raj May 31 '21 at 01:54
  • yeah, so you've gone through the install of the drivers for that? as per the link you gave earlier? i.e. Raspbian requires manual driver installation and manual update after each kernel upgrade. Limited range** - I'd get a different USB wifi to be honest - seems like too much work and with limited range, why would you bother – Jaromanda X May 31 '21 at 01:57
  • Nope, I have not done any new installation. If you have link, please give me. Thank you. – Raj May 31 '21 at 02:00
  • I didn't say a "new installation" ... I said that page you linked to requires *manual driver installation* - the link is in the page YOU linked to so - find your device in the link you provided and follow the link to the instructions they recommend – Jaromanda X May 31 '21 at 02:27
0 Answers0
