I need help to run Raspbian on RAM.
I need to this in order to make the Pi powerfault safe. I want to be able to remove power to the Pi without problem.
I need to be able to remove the SD card after the system has booted. I stripped down a netinstalled Raspbian but now I can't find how to boot it from RAM.
I have tried to modify cmdline.txt but without result.
Darth Vader
  • 4,206
  • 45
  • 69
user11466
  • Why do you need to remove the SD card? The RAM will require a constant power supply as well... – Wilf Dec 23 '13 at 21:35
  • I would direct you towards this first, and then consider a small Lithium Ion battery momentary backup solution with a shutdown trigger using the GPIO pins. The RAM on the Pi is volatile (clears on power off) so that will not actually give you what you are wanting. – The NetYeti Dec 23 '13 at 22:27
  • I can point you to https://www.embeddedarm.com/about/resource/preventing-filesystem-corruption-in-embedded-linux http://www.tinycorelinux.net/ (not sure about the Pi 4 for tiny core) https://raspberrypi.stackexchange.com/questions/85524/how-do-i-make-the-os-reset-itself-every-time-it-boots-up/85569#85569 and http://www.enerco.si/content/overlay-filesystem-raspi One gent on the forum had used buildroot to make a r/o system but I cannot find the link. Leave the SD card in - you need it to boot again after power off / on! –  May 29 '20 at 10:16
0 Answers0
