The script mentioned in the darrenjw's answer downloads a pre-compiled module based on your kernel version. It's quite likely that one of these modules will work for you though you might have to search through the script to find the right module. The lastest one worked for me, I'd start by downloading and trying that.
wget http://dl.dropbox.com/u/80256631/8192cu-20120701.tar.gz
tar xfv 8192cu-20120701.tar.gz
sudo mv 8192cu.ko /lib/modules/3.1.9+/kernel/drivers/net/wireless/
sudo insmod /lib/modules/3.1.9+/kernel/drivers/net/wireless/8192cu.ko
If you then enter iwconfig and are presented with a list containing wlan0 then the module was successfully loaded. If none of the pre-compiled modules work then you may have to build your own, however, this isn't as simple as it should be.
Once you have the module loaded you will need to configure your network. Start by setting up the interface:
sudo nano /etc/network/interfaces
and add the below text to the end of the file:
auto wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa.conf
then:
sudo nano /etc/wpa.conf
and add the below text replacing NETWORK_SSID with your network name and NETWORK_PASSWORD with your password:
network={
ssid="NETWORK_SSID"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk="NETWORK_PASSWORD"
Secure the file with:
sudo chmod 600 /etc/wpa.conf
Now type sudo ifup wlan0 and you should be connected.
aptitude, you can usually useapt-getwith the same commands. All debian systems (raspbian, raspbmc) should haveapt-getinstalled by default. If not, you can download and install the deb package for apt-get. It makes software package installation (and system maintenance) much easier. And if you wantaptitude searchandaptitude showcommands, you can just dosudo apt-get install aptitudeto get it. – hobs Mar 10 '13 at 21:23
