I am trying to install PyQt5 on an RPi 4/ 4GB for use with the Oasis 3DP controller software: https://hackaday.io/project/86954/instructions?page=2
To do so I've had many problems trying different variations of sudo pip install PyQt5, sudo pip3 install PyQt5, sudo pip3.6 install PyQt5, etc. so I've been following a previous question: PyQt5 on a Raspberry Pi,
going the route of downloading the .tar for both sip and PyQt5, then running the configure.py file in each respectively before running sudo make and then sudo make install. I've successfully installed sip using this method, and have successfully run sudo make inside the PyQt5-5.14.4 directory. However, upon trying to run sudo make install, I get the following outputs:
pi@raspberrypi:~ $ sudo make install
cd QtCore/ && ( test -e Makefile || /usr/lib/qt5/bin/qmake -o Makefile /home/pi/Downloads/PyQt5-5.15.4/QtCore/QtCore.pro ) && make -f Makefile install
make[1]: Entering directory '/home/pi/Downloads/PyQt5-5.15.4/QtCore'
g++ -c -pipe -O2 -fno-exceptions -Wall -W -D_REENTRANT -fPIC -DSIP_PROTECTED_IS_PUBLIC -Dprotected=public -DPy_LIMITED_API=0x03040000 -DQT_NO_EXCEPTIONS -DQT_NO_DEBUG -DQT_PLUGIN -DQT_CORE_LIB -I. -I. -isystem /usr/local/include/python3.6m -I../qpy/QtCore -isystem /usr/include/arm-linux-gnueabihf/qt5 -isystem /usr/include/arm-linux-gnueabihf/qt5/QtCore -I. -I/usr/lib/arm-linux-gnueabihf/qt5/mkspecs/linux-g++ -o qpycore_post_init.o qpycore_post_init.cpp
In file included from ../qpy/QtCore/qpycore_api.h:30,
from qpycore_post_init.cpp:25:
../qpy/QtCore/qpycore_public_api.h:26:10: fatal error: sip.h: No such file or directory
#include <sip.h>
compilation terminated.
make[1]: *** [Makefile:1227: qpycore_post_init.o] Error 1
make[1]: Leaving directory '/home/pi/Downloads/PyQt5-5.15.4/QtCore'
make: *** [Makefile:82: sub-QtCore-install_subtargets-ordered] Error 2
I've tried manually copying sip.h from the /home/pi/Downloads/sip-4.19.25/sipgen directory, but then it spits out an even longer and more incomprehensible error message to the terminal. Has anyone else tried running the controller software for Oasis from an RPi or has experience trying to install PyQt5 for this specific version of Python?
sudo make install, but the log you attached features a different command (much longer and withoutsudo). – Dmitry Grigoryev Apr 09 '21 at 07:35
