I have a Raspbian installation on which I installed a lot of stuffs.
A few weeks ago, I bought a Class10 16Gb card and cloned my raspbian installation from my old Class4 4Gb SD card to this new SD card.
I did not expand the old FS to the whole 16Gb partition (I planned to create another partition later but this is not a problem for me).
The problem
Everything worked fine until yesterday:
- impossible to log-in using SSH
- after rebooting (connecting my TV screen and a keyboard) nothing happened
- since that, every time I connect my power supply, the screen flashes but nothing happens
- I tried to re-use my old Class4 SD: booting and running was OK
- Connecting my Class10 SD card to another linux machine:
- IO errors
- unable to perform any fsck (due to errors)
When I shutdown my RPi, I always use "shutdown -h now" command. Yesterday, my RPi was up and running since 4 days.
What I already did
Testdisk
I ran testdisk and it indicated some errors
check_FAT: Unusual number of reserved sectors 16 (FAT), should be 1.
Warning: number of heads/cylinder mismatches 255 (FAT) != 1 (HD)
Warning: number of sectors per track mismatches 63 (FAT) != 1 (HD)
1 * FAT16 LBA 8192 122879 114688 [RPIBOOT16G]
2 P Linux 122880 7829503 7706624
I did not write modification to the SD card using it.
FS backup
I mounted my fs as read-only and tried to copy (cp -a) the whole files to another directory (this is because I made some changes since I cloned from Class4 to Class10 SD). Apparently, it finished without errors.
What should I do now ?
Now I have a backup of my files, but I don't know how to repair the failing SD card.
Should I rewrite partition table ? But how (which partition size for /boot, other partition to add, create a new MBR and how) ?
So what should I do now to restore my Class10 SD card with the backup I made ?
What tools, what procedure should I use ?
So I try booting again this morning with my class10 SD card and... it worked ! Maybe be it just needed to sleep for a night !
– lauhub Dec 12 '13 at 08:26
