What I mean by something else I mean connecting my external ssd (uses usb-c) to my pi rather than the usb ports as those are slower. I have read on usb-c Port of RasPi 4 used for anything else but Power? that power and data is populated in the port, but I was wondering. Can you use something like a USB hub or apple's multiple-connector-into USB-c? (beacause the apple one allows a usb-c power)
            Asked
            Active
            Viewed 815 times
                    the pi4 has 2xUSB3.0 ports ... and I use them for SSD at 5Gbps (max rate for USB 3.0) – Jaromanda X Feb 03 '21 at 02:00
                    Yes but that gives 640 mbps whereas my ssd goes up to 1050 – TennisBowling Feb 03 '21 at 02:03
                    SSD on a USB3.0 port should go to 5 gigabits per second ... if you're only getting 640 megabits per second, and the device is only capable of about 1 gigabit per second, then the USB-C connector won't help anyway - get a better USB3.0->SATA connector – Jaromanda X Feb 03 '21 at 02:28
                    640 megaBYTES per second – TennisBowling Feb 03 '21 at 03:04
                    Oh, well that is the maximum then – Jaromanda X Feb 03 '21 at 04:53
                    The USB-C on a RPI4 is purely for power and not data. – Simon Banks Aug 10 '21 at 13:35
            The USB-C connector on the Pi DOES NOT implement USB-C. It is used for power and a USB-2 OTG interface.
- 31
- 101
- 209
