I have an Access Point set up on my Raspberry Pi 4 using a wifi dongle and hostapd. Everything works great, but when I start to transfer a file over FTP, the connection aborts at around 1 GB and I have to reconnnect to the AP.
Is there a way to solve this problem?
  • Do you stay connected indefinitely if you're not using FTP? – Dmitry Grigoryev Feb 17 '21 at 13:11
  • Yes I think so, I just noticed the problem when I transferred a large file via FTP. But I think it happens always, when I need big bandwidth and it looks like there is already a solution for that problem. – user11748507 Feb 17 '21 at 14:55
I have seen similar behavior because of weak firmware. Not sure if it also helps in your case but it might be worth a try. You can downgrade the firmware to a more stable version. Have a look at Access point as WiFi router/repeater, optional with bridge. At the beginning there is a part, labeled IMPORTANT UPDATE on 2020-09-02, that described how to downgrade the firmware.
  • 42,107
  • 85
  • 197
