I followed this tutorial to set up my Bluetooth dongle and get it running. I have the same Bluetooth dongle that is in the tutorial, yet I can not seem to get it to work. I get to step "C" and then I run into problems. Here is some commands I ran to diagnose the problem:
$ hcitool scan
Device is not available: No such device
$ lsusb
Bus 001 Device 009: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
$ hciconfig dev
hci0: Type: BR/EDR Bus: USB
BD Address: 00:1B:10:00:2A:EC ACL MTU: 1017:8 SCO MTU: 64:0
DOWN
RX bytes:1355 acl:0 sco:0 events:49 errors:0
TX bytes:204 acl:0 sco:0 commands:48 errors:0
$ hciconfig -a
DOWN
Features: 0xff 0xff 0x8d 0xfe 0x9b 0xf9 0x00 0x80
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy:
Link mode: SLAVE ACCEPT
$ hcitool dev
Devices:
$ sudo hciconfig hci0 piscan
Can't set scan mode on hci0: Network is down (100)
$ sudo hciconfig hci0 reset
Can't init device hci0: Operation not supported (95)
$ /etc/init.d/bluetooth status
[ ok ] bluetooth is running.
$ sudo bluez-simple-agent
File "/usr/bin/bluez-simple-agent", line 104, in <module>
path = manager.DefaultAdapter()
File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 70, in __call__
return self._proxy_method(*args, **keywords)
File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 145, in __call__
**keywords)
File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
message, timeout)
dbus.exceptions.DBusException: org.bluez.Error.NoSuchAdapter: No such adapter
Any suggestions? Power isn't the issue since I'm running the dongle from a powered USB hub.
I do not want solutions that tell me to downgrade my software. That is not a solution, that is a workaround.
hcitool dev? Since bluetooth seems to be running on the Raspberry Pi, did you check that bluetooth on your mobile device is discoverable? Also check this guide and this guide. – uelboud Dec 04 '13 at 18:17root@raspbmc:/home/pi# /etc/init.d/bluetooth status [ ok ] bluetooth is running would love any input
– Black Jan 13 '14 at 08:55org.bluez.Error.NoSuchAdapter:<- that error, as ambiguous as it sounds, kind of means it cannot open the port to thehciprofile of the Bluetooth protocol. This, unfortunately is a vendor specific issue, where the software is requesting a GUID "Profile" that doesn't exits. I had this issues with SPP, and it a bloody nightmare to get working. Possibly because the vendor used an out of date specification or uses a custom GUID that is no longer supported in the latest version of what ever you are using. Try and find working dongles – Piotr Kula Apr 14 '14 at 16:23
