So, I have the Raspberry Pi 4B with a Plex server set up and another Express server I'm running for a local website. The problem is that after a certain while (a few hours or so) I can no longer connect to the website; I get the error:
192.168.0.61 took too long to respond
I can sometimes connect to it through my phone after waiting for a bit.
The Plex server also stops working so I can't stream any videos from it.
When I try to SSH into the Pi, it says:
connect to host 192.168.0.61 port 22: Connection timed out.
All of these work perfectly fine for a few hours after startup, but then something happens with the Pi (no idea) and they suddenly stop working. The IP is static so that isn't the issue. I've checked the router and the Pi is connected when these errors occur. If I reboot the Pi then everything works fine, but then I just encounter the same issue after a few hours.
I have no clue at all what could be causing this. Any help would be appreciated, thanks.
Edit:
Firmware Version (from /opt/vc/bin/vcgencmd version
): 194a85abd768c7334bbadc3f1911c10a7d18ed14
" Famous last words :) – Seamus Jan 26 '21 at 23:26"I have no clue at all what could be causing this."
And as it seems you've resolved your issue, let's just leave it at that? – Seamus Jan 27 '21 at 22:30
