I'm not able to receive GPS data.
The jumpers are placed in the top position (A)
AT commands return the following:
>>> ser = serial.Serial("/dev/ttyUSB2",115200)
>>> ser.write(('AT+CGPS=1,1'+  '\r\n' ).encode())
13
>>> ser.write(('AT+CGPS?'+  '\r\n' ).encode())
>>> ser.write(('AT+CGPSINFO'+  '\r\n' ).encode())
13
python code ####################################### '''
import RPi.GPIO as GPIO
import serial
import time
import pynmea2
ser_send = serial.Serial('/dev/ttyUSB2',115200,timeout=1)
ser_receive = serial.Serial('/dev/ttyUSB1',115200,timeout=1)
ser_S0 = serial.Serial('/dev/ttyS0',115200,timeout=1)
def parseGPS(string):
    if 'GGA' in string:
        msg = pynmea2.parse(string)
        print(str(msg))
        print("Timestamp: %s -- Lat: %s %s -- Lon: %s %s -- Altitude: %s %s" % (msg.timestamp,msg.lat,msg.lat_dir,msg.lon,msg.lon_dir,msg.altitude,msg.altitude_units))
    else:
        print(f' doesnt contain GGA: {string}')
def check_conn(conn):
    return conn.name, conn.is_open
def send_at(command,expected_result,timeout):
    name, state = check_conn(ser_send)
    print(f'{name} is {state}')
rec_buff = ''
if state:
    ser_send.write((command+'\r\n').encode())
    time.sleep(timeout)
    if ser_send.inWaiting():    #something was received in the buffer
        time.sleep(0.01 )
        rec_buff = ser_send.read(ser_send.inWaiting())   # read the buffer
    if rec_buff != '':
        if expected_result not in rec_buff.decode():
            print(command + ' ERROR')
            print(command + ' returned:\t' + rec_buff.decode())
            return False
        else:
            print(f'---------- response from AT command: {rec_buff.decode()}')
            return True
    else:
        print('GPS is not ready, returned nothing')
        return False
def get_gps_position():
    rec_null = True
    answer = False
    gps_started = False
    print('Start GPS session...')
    while not gps_started:
    rec_buff = ''
    send_at('AT+CGPS=1,1','OK',1)
    time.sleep(2)
    gps_status= send_at('AT+CGPS','OK',1)
    if gps_status:
        gps_started = True
while 1:
    answer = send_at('AT+CGPSINFO','+CGPSINFO: ',1)
    #readings = list()
    print('######################## USB1  ')
    while ser_receive.inWaiting() >0:
        readings = ser_receive.readline().decode()
        parseGPS(readings)
        #readings.append(ser_receive.readline())
    # testing another port
    print('######################## S0  ')
    while ser_S0.inWaiting() >0:
                    readings = ser_S0.readline().decode()
                    parseGPS(readings)
    if answer:
        answer = False
        rec_buff = ser_send.read(ser_send.inWaiting()).decode()
        if ',,,,,,' in rec_buff:
            print('GPS is not ready')
            #rec_null = False
            print(f'{ser_receive.name} received {readings}')
            time.sleep(2)
        else:
            time.sleep(2)
    else:
        print('error %d'%answer)
        rec_buff = ''
        send_at('AT+CGPS=0','OK',1)
        return False
    time.sleep(1.5)
All I see is this:
/dev/ttyUSB2 is True AT+CGPS ERROR AT+CGPS returned: AT+CGPS ERROR
OK
end of response ######################## USB1
doesnt contain GGA: $GNGNS,,,,,,NNN,,,,,,*1D
doesnt contain GGA: $GPVTG,,T,,M,,N,,K,N*2C
doesnt contain GGA: $GPGSA,A,1,,,,,,,,,,,,,,,*1E
doesnt contain GGA: $GNGSA,A,1,,,,,,,,,,,,,,,*00
doesnt contain GGA: $BDGSA,A,1,,,,,,,,,,,,,,,*0F
– Newbie_dude Jan 22 '21 at 15:29
