I wanna connect two RPis together with an ethernet cable. I did it and test with ping function and it works, I can communicate.
But for my task I have to be sure that the IP addresses are static on eth0, I don't know if it's the case. Moreover I would like to chose them myself because they don't follow the same pattern (one is 169.254.62.28 and the other 169.254.226.136).
I checked on Google and it seems I have to modify the file /etc/dhcpcp.conf, but all the information I found is when the Pi is connected to a switch/router. So, I don't know what I have to put for this 2 data:
#static routers=?
#static domain_name_servers=?
Can I just modify static ip_address ignoring the previous ones?
Thanks in advance for your help.
*.localmDNS network names instead of the ip addresses. Most questions on this site are about static ip addresses. No, it does not make things simple. On the contrary, it makes things more complicated if you do not understand detailed networking. Please have a look at all the other answers about static ip address. – Ingo Jan 20 '21 at 22:17
