I have a raspberry pi 4 running raspberry pi os lite(headless). I have a wifi dongle attached to the pi for a better wifi signal (wlan1) as the built-in one was giving me issues, but I couldn't get wlan0 to connect to the network either. I'm using wpa_supplicant which worked perfect at my house but the location I'm at now has a hidden ssid and that seems to be the issue.
Ive tried using scan_ssid=1 which I thought would be the solution but it just didn't connect witch I thought to be very odd. I've tried adding a bunch of other options to get it to work such as 'proto', 'key_mgmt', 'pairwise' etc.
If I use sudo raspi-config to change the wifi network I get the error 'Could not communicate with wpa_supplicant' and 'There was an error running option N2 Wireless LAN'
here is the network configuration in /etc/wpa_supplicant...
update_config=1
country=US
network={
ssid="Hidden_Network"
scan_ssid=1
psk="password"
key_mgmt=WPA-PSK
output of 'ipa && ipr'
inet6 ::1/128 scope host
link/ether b8:27:eb:bd:b8:c5 brd ff:ff:ff:ff:ff:ff
inet 10.0.0.100/8 brd 10.255.255.255 scope global noprefixroute eth0
inet6 fe80::fb4:fdb9:f917:c380/64 scope link
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:e8:ed:90 brd ff:ff:ff:ff:ff:ff
4: wlan1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 84:16:f9:1a:1e:2e brd ff:ff:ff:ff:ff:ff
10.0.0.0/8 dev eth0 proto dhcp scope link src 10.0.0.100 metric 202
added lines to /etc/dhcpcd.conf...
interface eth0
metric 202
static ip_address=10.0.0.100
denyinterfaces wlan0
interface wlan1
metric 302
static ip_address=172.16.0.62
static domain_name_servers=1.1.1.1
static routers=172.16.0.1
ip a && ip r
is a help in diagnosing problems. It is always a problem to rely on default interface enumeration as there is no guarantee which will bewlan0
– Milliways Jan 18 '21 at 06:03wlan
does not seem to be connectedsudo iwlist wlan1 scan
will show what it can see. It is unclear what network you are testing (home or otherwise), why you have disabledwlan0
or why you are trying to use 2 different network segments. NOTE do not post Comments, edit your Question with details. – Milliways Jan 18 '21 at 06:44
