-1
I used to have a Netgear Nighthawk router where my raspberry pi 3 was able to connect to WiFi, ethernet, SSH, everything I needed.
Using the same Pi but now plugged into a TP-Link Archer A9 router, I can not get any connection at all with an ethernet cord. The router interface at (192.168.0.1) does not show a wired connection coming from the Pi either. The router LED glows as if the Pi's ethernet cord is connected. If I connect the Pi to the router through WiFi, I am able to then see the Pi on the TP-Link router's interface (192.168.0.1). If I use the IP address in this interface to SSH, it works! However, it still doesn't have internet access.
For example, when the pi is connected to the router through WiFi, I am able to SSH into the pi and execute the following.
pi@raspberrypi:~ $ sudo ping google.com
PING google.com (172.217.4.78) 56(84) bytes of data.
From 192.168.1.5 (192.168.1.5) icmp_seq=1 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=2 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=3 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=4 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=5 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=6 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=7 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=8 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=9 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=10 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=11 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=12 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=13 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=14 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=15 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=16 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=17 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=18 Destination Host Unreachable
From 192.168.1.5 (192.168.1.5) icmp_seq=19 Destination Host Unreachable
^C
--- google.com ping statistics ---
21 packets transmitted, 0 received, +19 errors, 100% packet loss, time 928ms
pipe 4
pi@raspberrypi:~ $
Edit: Suggested to run the following commands.
pi@raspberrypi:~ $ ip a && ip r
    inet6 ::1/128 scope host
    link/ether b8:27:eb:c0:4c:d6 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.5/24 brd 192.168.1.255 scope global noprefixroute eth0
    inet6 fe80::9caa:4457:4097:e21a/64 scope link
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether b8:27:eb:95:19:83 brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.247/24 brd 192.168.0.255 scope global noprefixroute wlan0
    inet6 fe80::2305:6f6d:a1c4:9e73/64 scope link
default via 192.168.1.1 dev eth0 src 192.168.1.5 metric 202
default via 192.168.0.1 dev wlan0 proto dhcp src 192.168.0.247 metric 303
192.168.0.0/24 dev wlan0 proto dhcp scope link src 192.168.0.247 metric 303
192.168.1.0/24 dev eth0 proto dhcp scope link src 192.168.1.5 metric 202
pi@raspberrypi:~ $ ethtool eth0
Settings for eth0:
        Supported ports: [ TP MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
        Supported pause frame use: No
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
        Advertised pause frame use: Symmetric Receive-only
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
        Link partner advertised pause frame use: Symmetric Receive-only
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 100Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 1
        Transceiver: internal
        Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
        Current message level: 0x00000007 (7)
                               drv probe link
        Link detected: yes
pi@raspberrypi:~ $
Blake
You appear to have a perfectly working network.
Both interfaces are working, although they may not be doing what you expect (we do not know how you managed this or what you expect).
You seem to have 2 different network segments
eth0 is on 192.168.1.x
wlan0 is on 192.168.0.x
Unless you have set static IP Addresses (which is almost always a bad idea) they are connected to different routers.
  • So maybe the ethernet connection is remembering the old router for some reason? Thats the same xxx.xxx.1.x gateway – Blake Dec 13 '20 at 03:13
  • I didnt change anything in any settings by the way. I simply switched out routers and it is working on every other device. – Blake Dec 13 '20 at 03:22
