I am trying to create a secure ad-hoc network generated from a pi 3b+ running Buster. I would like to have a password prompt to show up when I try to connect to the network on various devices. Here is what my interfaces file looks like:
auto lo iface lo inet loopback
iface eth0 inet manual
auto wlan0 iface wlan0 inet static address IP netmask 255.255.255.0 wireless-channel 1 wireless-essid Network wireless-mode ad-hoc wireless-key KeyHere
I have also tried modifying the wpa_supplicant.conf file to add my password like so:
network={
    ssid="Network"
    psk="password"
    key_mgmt=WPA-PSK
And in my interfaces file I used:
auto wlan0 iface wlan0 inet static address IP netmask 255.255.255.0 wireless-channel 1 wpa_conf /etc/wpa_supplicant/wpa_supplicant.conf
But the network stopped showing up on my phone.
Update with info from a comment:
I'm using Buster. I connect to this network on my iPhone. I don't run an access point from my phone. The ad-hoc network is generated from the Pi. This is a Wifi-Direct connection.
  • 42,107
  • 85
  • 197
goodkid38
  • What operating system, what version do you use? What does it mean: "I select the network on my phone" - do you run an access point on your iPhone? Or what is this network on your iPhone? What ad-hoc connection do you try to use? Is it IBSS? WiFi-Direct? – Ingo Nov 23 '20 at 20:32
  • I'm using Buster. I connect to this network on my iPhone. I don't run an access point from my phone. The ad-hoc network is generated from the Pi. This is a Wifi-Direct connection. – goodkid38 Nov 23 '20 at 22:13
You are trying to use WiFi-Direct so you do not have to worry about security. WiFi-Direct uses WPA2 encryption by default.
You are using old style Debian networking managed with /etc/network/interfaces. This is deprecated on the Raspberry Pi OS based on Buster since years. I haven't used it for a long time so I cannot help much with it. I'm afraid you are alone with it.
This is not seen with your settings in /etc/wpa_supplicant/wpa_supplicant.conf. There you have to define some options specific to WiFi-Direct.
WiFi-Direct uses two authorization methods: "pin entry" and "push button". So for your application you have to use the pin entry method. This is done with commands using wpa_cli. I do not have an iPhone but an Android Phone so I can only give an example with it. You may have a look at Connect Android smartphone with Wi-Fi Direct to a Raspberry Pi. This will give you an idea how WiFi-Direct works. The settings and using wpa_cli on the Raspberry Pi should not make a difference, in particular the options in /etc/wpa_supplicant/wpa_supplicant.conf and the commands with wpa_cli.
  • 42,107
  • 85
  • 197
