I have to update from Python 3.7 to 3.8, just like in Updating Python 3.7 to 3.8. In my case, it is to run HomeAssistant.
I understood that apt cannot find the package in the default repository.
However, I couldn't find how long does it take for the package to be available, so I could know if it is worth waiting. Where could I find this information?
Moreover, if the package is not available yet, wouldn't it be because the stability not optimal yet? Otherwise, what would be the difference between the manual installation and the future repository-base apt installation?
Dan Chaltiel
  • 215
    Simple NEVER. The next Debian release will probably have 3.9 – Milliways Nov 02 '20 at 11:30
  • @Milliways but why? – Dan Chaltiel Nov 02 '20 at 11:51
    You'll need to wait for Bullseye to emerge from his stable. – Dougie Nov 02 '20 at 13:25
  • @Dougie I'm sorry but those comments are 100% cryptic to a noob like me. Could you explain a little bit? TMLI5. – Dan Chaltiel Nov 02 '20 at 14:00
    RaspiOS is based on DebIan. The current RaspiOS version is Buster. The next (in autumn 2021) will be RaspiOS Bullseye (the DebIan versions are named after Toy Story characters). You won't get a python version change except on a DebIan version change - because that's how DebIan likes to do it to remain a stable release. Bullseye is Woody's horse (so I was punning on the word stable as in "unchanging" and "accomodation for equine animals"). – Dougie Nov 02 '20 at 14:26
  • @Dougie the pun makes a lot more sense now :-) You should definitely make this an answer. Anyway, this means that I really have to install python manually. Would you have any opinion about the stability of such an install? – Dan Chaltiel Nov 02 '20 at 14:46
You'll need to wait for Bullseye to emerge as the stable version.
Dougie
  • 5,301
  • Thanks! So if this is a stability matter, does this mean that Python 3.8 will not be that stable on Buster? – Dan Chaltiel Nov 02 '20 at 17:02
  • No it means that DebIan don't want to make changes for a published distro. If you want rapid changes and leading edge versions us Ubuntu. – Dougie Nov 02 '20 at 18:00
