I am trying to make my raspberry pi automatically restart every week. But I am unable to create the cronjob as I get a error message that the temporary crontab file was unable to be created.
/home/pi $ crontab -e
/tmp/crontab.Kd1gSa: Read-only file system
Creation of temporary crontab file failed - aborting
But looking at the permissions of tmp it seems that all is in order:
/home/pi $ sudo ls -lsa /
total 80
4 drwxr-xr-x 21 root root 4096 Aug 29 16:51 .
4 drwxr-xr-x 21 root root 4096 Aug 29 16:51 ..
4 drwxr-xr-x 2 root root 4096 Aug 13 11:28 bin
4 drwxr-xr-x 2 root root 4096 Feb 13 2020 boot
0 drwxr-xr-x 17 root root 3860 Sep 14 23:08 dev
4 drwxr-xr-x 121 root root 4096 Sep 8 09:26 etc
4 drwxr-xr-x 4 root root 4096 Aug 22 01:45 home
4 drwxr-xr-x 18 root root 4096 Aug 22 01:45 lib
16 drwx------ 2 root root 16384 Feb 13 2020 lost+found
4 drwxr-xr-x 5 root root 4096 Aug 29 16:14 media
4 drwxr-xr-x 2 root root 4096 Feb 13 2020 mnt
4 drwxr-xr-x 6 root root 4096 Aug 22 01:45 opt
0 dr-xr-xr-x 176 root root 0 Dec 31 1969 proc
4 drwx------ 10 root root 4096 Sep 8 09:24 root
0 drwxr-xr-x 26 root root 880 Sep 18 06:02 run
4 drwxr-xr-x 2 root root 4096 Aug 13 11:30 sbin
4 drwxr-xr-x 2 root root 4096 Feb 13 2020 srv
0 dr-xr-xr-x 12 root root 0 Dec 31 1969 sys
4 drwxrwxrwt 18 root root 4096 Sep 19 00:00 tmp
4 drwxr-xr-x 12 root root 4096 Aug 21 23:55 usr
4 drwxr-xr-x 12 root root 4096 Sep 6 10:27 var
What could be the problem here?
As Seamus pointed out my file-system seems to be read-only. I used apple-pi-baker to flash this drive from a backup. I just don't have physical access to this device since its across the country atm at my university.
/home/pi $ mount -l -t ext4
/dev/mmcblk0p7 on / type ext4 (ro,relatime) [root]
I have added the fs check commands to the bootline which was in a different location than /boot
/home/pi $ sudo ls -lsa /media/pi/boot/cmdline.txt
1 -rw-r--r-- 1 pi pi 179 Dec 31 1979 /media/pi/boot/cmdline.txt
/home/pi $ sudo cat /media/pi/boot/cmdline.txt
console=serial0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes fsck.mode=force rw rootwait quiet splash plymouth.ignore-serial-consoles
I think my raspberry pi is able to boot to desktop due to the rw
in my cmdline. B/c without it I get read-only file system errors at boot. But I also this this might be leaving parts of the filesystem to be read-only?
/home/pi $ sudo df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 26G 21G 4.1G 84% /
devtmpfs 3.8G 0 3.8G 0% /dev
tmpfs 3.9G 52M 3.8G 2% /dev/shm
tmpfs 3.9G 370M 3.5G 10% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
tmpfs 788M 0 788M 0% /run/user/1000
/dev/mmcblk0p6 253M 55M 198M 22% /media/pi/boot
/dev/mmcblk0p1 2.4G 2.3G 87M 97% /tmp/tmp.5LW77DmOAt
rw
in an elevated command prompt – Gabriel Fair Dec 04 '22 at 19:00
